Question about Maytag Neptune MDE5500AY Electric Dryer
How do I access dryer drum for neptune dryer - Maytag Neptune MDE5500AY Electric Dryer
    Sergeant:
  • 222 Answers
Take the door screws off and take the opposite side screws off lift out the door, grab the vertical pieces of the front panel and twist them away from the opening while you pull out, then lean the panel forward about 2 feet and lift the panel up and out, this gives you access to the lint screen housing and the blower wheel and housing and eventually the entire heating element and belt, drum, motor etc. unplug this thing before you work on it !!! it will zap you !!
Posted on Sep 04, 2009
  • 146 Answers
SOURCE: change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Posted on Dec 22, 2007
SOURCE: Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Posted on Nov 21, 2008
Ben-mrfixit
  • 68 Answers
SOURCE: how do i get access to gas valve coils on maytag neptune series dryer
Here is a link of an exploded view of a dryer hopefully this can help you! have a good day! Ps don't forget to give me a rating if this was helpful!!! thank you
http://www.repairclinic.com/0100_17.asp
Posted on May 10, 2009
milten1
  • 1304 Answers
SOURCE: How do I access the drum to replace the screws on
four door screws hinges and other side
top botom both side
take off the door
take off the white cowel around the door
you should se two top dogs remove the bolts and the top will lift open
Posted on Oct 03, 2009
  • 8404 Answers
SOURCE: How do I access the drum of my Maytag Neptune
Try to pop the top up on it ... then remove the front. be careful of the wires on the door switch
Posted on Nov 02, 2009
Our maytag neptune dryer is squeaking. Can u please tell me the part needed? thanks
the most common problem on this unit is the rollers, one sits above the heater and the bearing dries out. I provided you with two links one where you can purchase the drum rollers you need two, the other link explains how to access the dryer to repair it.
Click Here Drum Rollers
http://www.appliancerepairlesson.com/2011/01/29/washer-and-dryer-atlantis-neptune-access-2/
Good luck with you're repair!
Mar 05, 2011 | Dryers
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
How do I gain access to the motor on my Neptune dryer
Open the dryer door.
Remove four screws - two are holding the door and two are holding plastic pieces opposite the door.
With the screws released, the front pannel of the unit will tilt forward and can be removed.
With the front pannel out of the way, two metal retainers found at the top front of the dryer can be released which allows for the top of the unit to be lifted up and removed if desired.
From this point, four more screws found on the front face were removed which allowed the front ducting and front part of the drum to be removed.
The drum was pulled out (work the belt to the rear of the drum while extracting it - optionally, you can release the belt tension by reaching in and removing the belt from the idler)
The motor is accessable.
Professionals may want to pull all the screws from the side pannel and remove it for easier access.
Jan 12, 2010 | Maytag Neptune MDG5500AW Gas Dryer
How do you remove the top off of a maytag neptune dryer 5500 series?
Take off the 4 phillips head screws around the door. the 2 sides will fold out, pull and the bottom panel will follow. after you have removed the panel you will have access to the frame. you will need to remove the top 2 5/16th screws. you will then lift the top panel and have a access to the top of the drum.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Rattle inside dryer drum
remove the front cover and then you can access the top cover screws to open top then you can locate and tighten screws
Jul 27, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Change rollers on a Maytag Neptune Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
169 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
