Question about Sceptre X37sv-Naga 37 in. LCD Television
Sceptre power supply short circuit - Sceptre X37sv-Naga 37 in. LCD Television
  • stump1985 Sep 05, 2009
    Won't power on read some of the solutions. Soldered in two new thermistors on the power board. wondering if there was something else I could check
    President:
  • Sceptre Master
  • 1,779 Answers
What would you like to know?
Posted on Sep 04, 2009
Sceptre X505BV no power
Could be an open internal fuse or power supply failure
Jun 22, 2017 | Sceptre Televison & Video
Sound but no picture
Try replacing the bulb, checking the power supply for a short circuit and examining the motherboard for burn marks or other signs that the screen's gone bad. Worst-case scenario, a new 32" TV costs a lot less than it did a few years ago, and Newegg.com often has good sales.
Aug 31, 2012 | Sceptre X32BV-Naga 32 in. LCD TV
It come on then it gos off, put on the power.it come back on,then gos off again.
the problem of your lcd monitor is on cathode driver,its a highvoltage circuit that supplying the cathode tube that elluminate the lcd, there are two sets of driver lower and upper tube maybe one of those are shorted or defective...
Aug 17, 2011 | Sceptre DCL9a
Sceptre X7G komodo II Power light and screen flash about every second. Could it be the blanking circuit?
Look for bad caps with domed tops as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/SCEPTRE/Sceptre%20X7G/
should repalce the caps in a set.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 24, 2011 | Sceptre X7G Komodo II 17 in. Flat Panel...
I recently acquired a sceptre x9g Naga V monitor which has developed a problem. It produces a wonderful image which may last 5 min or 5 sec, then goes black. If I turn it off or unplug the monitor the...
It may have dying power supply due to bad DC filter caps like the 17" version.
http://s807.photobucket.com/albums/yy352/budm/Sceptre%20X7G/
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Dec 30, 2010 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
My Sceptre x20wg has gone blank. The blue light is on and "clicks" every couple of seconds. There is no display
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Sceptre and all monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 16, 2010 | Sceptre X20WC (Black) LCD Monitor
My monitor wont come on it will have a white screen for moments then go black
Power supply will be the first place to look, make usre that it does put out 5vdc for logic and 12~18vdc for the backlight inverter circuits.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SCEPTRE monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 07, 2010 | Sceptre X20G-Naga II 20.1" Flat Panel LCD...
Was working fine for a while ,then started acting ...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Sceptre monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 19, 2010 | Sceptre 17" LCD Monitor
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with www.lcdrepair.net if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G-Komodo IV
I recently came accross one of these monitors (Planar PE191M) with the identical issue. The resolution was to replace the two 470ufd 25V capacitors that are located on the main power board. The main power board also contains the audio circuit and more importantly the inverter circuit that drives the CCFL backlighting. The suspect caps were identified using an ESR meter; if you happen to have one of these meters you can confirm this is the issue with your unit(s), alternatively you can just replace the two capacitors and see if it resolves your issue. Hope this info helps someone out there.
Sep 05, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X37sv-Naga 37 in. LCD Television Logo
261 people viewed this question
Top Sceptre Televison & Video Experts
Jaime Hernandez
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
