Question about Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor
Dell 2208wfpt monitor that turns on but screen comes in and out
I have a dell 2208wfpt monitor that turns on but the screen comes and goes, mostly goes
  • 26 Answers
Video converter board ha to be changed
Posted on Sep 04, 2009
Dell 2208wfpt settings for portrait rotation?
Andrew Scharlach,
Are you changing the rotation using the ctrl+alt+right arrow. left arrow or down arrow? That is how i change the rotation on the screen. If needed lower the resolution in the display settings in control panel.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 24, 2015 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
Dell 2208WFPt no power - nothing.
Check the cord at the wall and the back of the monitor. If you can use a known-good cord, and still nothing, then your best bet is replacing the monitor completely.
Dec 12, 2012 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
2208wfpt flickering, not staying on
The problem is in the power supply/inverter board, there are more than likely one or more bad capacitors that open, "sometimes bulges at top" the other concern is one of the inverter transformers may be bad, or a failing backlight behind the display.
Apr 22, 2012 | Dell UltraSharp 2208WFP 22" Widescreen LCD...
2208wfpt
The problem is caused by one or more capacitors that have opened in the power supply/inverter board, sometimes they show a bulge at the top making it easier to spot.
Monitor comes on for a split second , and then off
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Dell 1704 monitor goes to black screen after one
Hi my name is Rain.
Ok so that im clear on the problem. your monitor will come on but in a matter of seconds it goes to a black screen?
If this is the problem. The answers you seek will most likely
be in your video card.
Try this test:
  • Unplug monitor from the computer.
  • Turn on monitor .
  • Look for monitor self test screen.
If you see the monitors self test screen then your problem indeed is
the video card . You will need to replace the video card inside of the computer.
Nov 23, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell Inspiron 1100 screen goes into power saver mode after 45 sec
it sounds like your most likely having trouble with the hibernate feature try this
start>>control panel>>power options>> click on the hibernate tab
un check enable hibernate mode
this should fix your issue
Apr 10, 2009 | Dell Computers & Internet
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Black Screen
No, this is typical problem for defective inverter. Mostly screen appears for some seconds and then turn to black. If you are technician, you can use this link :-).
http://www.lcdrepair.us/1702inverter1900x.html
Oct 01, 2007 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell UltraSharp 2208WFP 22" Widescreen LCD Monitor Logo
1,037 people viewed this question
Alun Cox
