Question about GE (PSS26MSRSS) Side by Side Refrigerator
Exits to the door.
My ice maker has frosted up at the place where the ice comes out into the door. It seems like the rubber gasket in the door that keeps warm air out is dead. Is this replacable? This is the gasket above the ice and water dispenser in the door. Not the door gasket.
  • GE Master
  • 1,606 Answers
Remove the bottom toe plate by removing a screww on each side in the front . Disconnect the electrical connector that comes out from the bottom of the freezer door ( this removes all power to the door ) . Using a small screwdriver , under the bottom of the door display board , twist slightly on the left and right portion of the board ( to remove the display board . Disconnect the 3 plug ins from the board and remove . There are 4 screws holding the white housing shield in place ( 1 on each corner ) . Remove these and slide the housing out . Then you will be able to see the solenoid and plunger on the upper right . Usually , these 2 parts rust , so the flap will not open or close completely . Part number for the solenoid and plunger is WR62X10055 . The solenoid comes with the 2 wires and plug already attached . Reassemble in reverse .
Posted on Sep 04, 2009
Testimonial: "Very informative. Now I'll be able t decide whether to fix it myself or call a repairman. "
Ice maker chute not sealing. Ice and frost is building up around the ice maker and the chute door in the freezer door.
Thank you for your post, friend!
It sounds like there could be a possible air leak within your Frigidaire refrigerator. I would check the gasket that goes around your refrigerator. The best way to test this would be to place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket.
If the seal checks out to be fine it could be a possible problem with your dispenser or leak within your icemaker. I would recommend having a professional come out to properly diagnosis your appliance. I hope this information is helpful. -Matt
Oct 06, 2014 | Frigidaire Refrigerators
Frosting in freezer drips water no ice maker installed in referigderater
check that door should be closed tightly,no air gaps in rubber gasket,check hole for water drain at bottom side,it should be open to drain
Sep 29, 2014 | Amana ABB2224WEB
I have a Kelvinator KC1 37A fridge freezer and the freezer section keeps icing up far too much. After defrosting within 3 days it has iced so much that the door won't shut. It only seems to have one dial...
A couple of things can cause this problem.
First - has the one temperature control you mentioned been accidentally changes to a lower temperature? If so, turn it down a notch or two.
Second - Is the door's rubber gasket worn, out of place or needs cleaning and not sealing properly?
If this is the case, it's letting warm air in and causing it to liquefy and for frost/ice in the freezer compartment. Open the Freezer compartment door and carefully inspect the gasket. If it has moved and out of place anywhere on the door frame, put it back in place. Is the door gasket dirty? If so, clean it with mild soap and water. Dry it and close the door.
To check to see if the door gasket is sealing tight, open the door and stick an unfolded dollar bill between the gasket and the freezer compartment opening. Close the door and try to pull the bill out. Do this in several places all around the door. If the bill pulls out easily, then the door gasket needs to be replaced. You can probably replace it yourself, if you can find a supplier for the gasket.
I suggest you try the following link, as they stock a lot of parts for Kelvinator appliances
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Refrigerator&Brand=Kelvinator&Material=Rubber
Hope this helps solve your problem.
Feb 17, 2011 | Heating & Cooling
Ice sticing in ice dispenser chute
only use ice from the ice maker, some frost is normal, but , lower temp in freezer
May 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Oct 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
ICE MAKER FROST UP AT CHUTE
is this a u-line? Or a GE? If its a U-line make sure the freezer door is closing and sealing. If its a GE then check the gasket and make sure that is sealing.
Jul 29, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
My kenmore side by side w/ ice maker is working
Air leaking in around the door gasket or the door flam the ice comes out of.
Jul 02, 2009 | Kenmore 57029 Side by Side Refrigerator
Our KitchenAid just started leaking. it is coming from the front ice dispenser on door. seems many people are having this problem. there is also "snow" on ice maker and bucket. and the temperature...
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
The excess frost on the ice maker and bucket can be caused by the ice chute door not closing all the way or a leaky door gasket letting air in.
Jul 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice cube flap door
try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Oct 22, 2017 | GE Refrigerators
Frost on ice maker
look at the chute where the ice comes out the door and see if the door in there is sticking open and leaking air in some times it helps to hold a flashlight on the out side aimed up the chute while lookin down on the inside
Dec 31, 2007 | Whirlpool GS6NBEXR Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
76 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
