Question about Olevia LT42HVi 42 in. LCD Television
After I reset my Olevia 542-B11 with "Factory Setting", the unit no longer performs channel scan. I can navigate to the "auto channel search" manu. But, neither the "air" nor "cable" option work, whether I press the "munu" button or the "enter" button. Under "cable", the option is fixed at "standard" (it has an orange frame. How can I reset the unit to get to search channels again?
  • Anonymous Mar 25, 2014
    Auto channel search option in new memory in black 500
  • 9 Answers
Unplug televison for about 1 minute.
Go into menu picture>mode> powerup> and switch to home mode
Posted on Sep 05, 2009
  • 2 more comments
  • Joel Silva Jul 28, 2011
    Thank you solderhead, your instructions saved me a lot of headaches! I had the same problem as " tsagaantemee". It worked!.
  • worshipwarri
    worshipwarri Jan 07, 2013
    I love you solderhead!!! You are now my super tech. thanks
  • Daniel Chavis Apr 13, 2013
    Thank You solderhead. You saved my bacon! I was getting ready to buy a new tv.
  • solder head Apr 14, 2013
    Thanks glad I could help, ps 7 years and the set is still working only had to change one capacitor in all that time. Tough good tv
How to do a complete initial setup on olevia 542-b11
Olevia initial setup Questions & Answers - Fixya
www.fixya.com > Forum > Tags > initial setup
I hit the reset buttom to default how do you setup auto channel ... i have no channel its not listed in the set up menu you have to do a complete initial setup .
How Do I Set Up Channels On An Olevia Television
www.mademan.com/mm/how-do-i-set-channels-olevia-television.html
Jun 17, 2010 - If you have figured out how to set up your cable box or antenna to yourOlevia TV, then the hard part is done and you just need to find an ...
Olevia auto channel search Questions & Q&A -Q&A - Answer
www.dqrkc.com/tags/auto_channel_search/browse/olevia
Dec 22, 2015 | Olevia Televison & Video
Olevia 537-B11. Why is there a blue screen with a "no signal" message?
try main menu look for input should be Air (antenna) ,cable, av1, av2, hdmi1, hdmi2 and perhaps more. do an automatic channel scan if you have an antenna hooked up. will take several minutes scanning
Oct 09, 2015 | Televison & Video
Olevia 542-b11 LCD HDTV won't turn on. Blue light blinks twice
My Olevia 42" television is several years old. In March of 2012, the infamous "TV will not power on" problem started.
The blue LED light on the front of the TV would go off for a split second, then light up again. The television would not start.
If you are handy with small tools and a soldering iron, you can change the capacitors on the power supply. My Olevia is a model 542-B11.
I bought the repair kit off eBay from seller: sghill99
As of this writing, the seller has sold 37 of these kits. The title of the auction is: Repair Kit, Olevia 542-B11, LCD TV, Capacitors
And if the url is still active, it is: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230554940338&ssPageName=ADME:L:OC:US:3160
I made the repairs in March 2012 and it is now August 2012 and the television is still working great. It is turned on and off several times every day.
Oct 25, 2011 | Olevia LT42HVi 42 in. LCD Television
I can get to the menu settings, go up to the auto channle search,,, but my tv won't do the search,,, what can i do ?
I have the same problem. Cable went out, hooked up an antenna and it scanned ok. Hooked up a diff amplified ant, worked the same. So watched videos. Next morning tuner would no longer scan or add channels. Now it will not even factory reset. Get to Auto Scan and it goes no further, cable or air.
Mar 28, 2011 | Syntax Olevia 537H Television
Olevia 232 s12 Accidentally hit factory reset. now no channels in list. how do I get my channels back?
You'll need to reprogram the channels.
Typically this is found under the settings in some sort of auto program section of the menu.
On most newer televisions, the setting is found under a 'Channel' section.
Just select auto program and your source, whether it be an antenna or a cable source.
When the auto program is completed, you'll have your channels back.
Mar 05, 2011 | Olevia Televison & Video
How can I get my Olevia tv back to the factory settings?
It's at the bottom of the Miscelaneous Menu (Book & wrench icon):
"Reset Factory Settings:
Initiating Factory Default will reset all OSD settings to original
manufacture settings. The only items, which will remain unaffected are:
Clock
Auto Scan Channels
Edited Channels
Parental Control Password "
If you are trying to take off the parental password:
"Note: If you forget the password, press "9999" to lift the Password lock
and change to a new preferred password. "
"" = Quotes straight out of the manual.
Nov 06, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Jan 21, 2008 | Olevia LT23HVX 23 in. LCD Television
No channels
i had the same damn problem for 3 long hours but i found a solution i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Sep 21, 2007 | Olevia LT32HVE 32 in. LCD Television
Olevia LT42HVi 42 in. LCD Television Logo
2,209 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
