Question about Microsoft Windows XP Professional for PC
Windows not booting
I had installed dual OS in my comp. That are xp n fedora . i deleted the fedora by using windows disk management system. now im not able to xp since it is not booting
  • drcspy
    drcspy May 11, 2010
    some hint as to what actually DOES happen when you TRY to boot xp would be helpful........
  • 555 Answers
Regarding on your problem, the main issue their is the booting problem of XP after you delete the fedora operating system. That's common problem especially when the computer are in dual boot OS then you delete the other OS. Now, the reason why it usually fall into this problem its just because the XP is your core OS then you install Linux Fedora inside in XP so whatever changes you have done in fedora particularly deleting Linux OS inside XP affects the overall performance of your XP and eventually if you delete the Fedora without proper unistallation process done by Linux OS then the Boot Loader of your XP will also corrupt or delete that's the main cause of boot failure in your XP OS. Now the best solution there is to repair your XP by inserting the XP CD Installer and boot the CD to repair your OS or you can reinstall the XP OS without formatting the storage to prevent the lost of your data that has not yet already copyed a back up.
Please do this recommendation to save and restore your XP.
thanks
Posted on Sep 04, 2009
    President:
  • 1,335 Answers
You're going to have to go back to the beginning and clean your hard drive by reformatting it to make sure your don't have hard problems on the disk. Once you have reformatted the disk you will have to reinstall XP. This way you know what your are starting with. Make sure you make a recovery disk once you've reloaded the OS.
Reinstall your applications and enjoy working with a clean system.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Ok follow these steps. but do it appropriate
change boot to primary CD
so it would boot from CD...
boot from your XP boot cd and again click on install , xp by default it will find your drive that has XP and will ask if you would like to delete or repair
choose repair and it will go to command prompt
now under command prompt , rewrite the boot data
C:\ BOOTCFG /Rebuild
this is the command to rewrite the Boot files, n
NOW CHANGE THE BIOS TO PRIMARY BOOT FROM DISK
NOW IT WOULD FIX
IF IT WONT FIX REPLY ME
Uninstall os linux ubuntu 13.10 from my laptop
Are you dual booting? Windows and Ubuntu? What version of Windows? You maybe able to reclaim the space by using the Disk Management (right click "My Computer" select Manage then select Disk Management). In there you will see NTFS for your Windows partitions, and something like Unknown for the linux ones, you can then delete the linux partition and possibly extend your NTFS partition to use the free space (depending on version of windows).
If this is a standalone Ubuntu install, you should be able to just use the installer disk for another OS and boot it to reformat the drive.
good luck!
Jan 10, 2014 | Computers & Internet
How to install linux fedora 7, already i am using windows 7, now i want to use dual os's , please tell me how to install linux.
WARNING: I will not be responsible for any data loss that occurs. It is recommended to backup your hard disk to external media before commencing any of these operations. 1. Download and burn the Fedora LiveCD. It is recommended that you use the latest version, Fedora 14, instead of 7, but you can use Version 7 anyways. 2. Boot up with the Fedora LiveCD. Select Install. 3. Follow the instructions displayed onscreen. When you reach the partitioning screen, you will need to resize your Windows partition. Resize it to a reasonable size (1024MB =1GB). Leave at least 5GB for Fedora to install. 4. After resizing, select the "Use Free Disk Space" option, and continue installing. 5. Your system will be installed with Fedora and the GRUB bootloader. The GRUB bootloader will allow you to boot into both Windows and Fedora.
I hope this post helps you. I appreciate your vote very much!
Mar 03, 2011 | fedora Linux Operating System
How to remove an operating system in a dual boot?
In Windows Xp, you can install two operating systems on the same hard disk of one computer.
Whether you have two copies of Windows Xp, or two different operating systems, then you end up with dual boot machine when you restart your Windows Xp computer.
Dual boot means, the system will give you a choice of two operating system. For example, if you have two Windows Xp copies A ans B, the prompt will offer you to choose A or B to boot from.
Also, dual boot machine can be used to have Windows Xp, and Linux O.S. installed on the same computer.
In the case where you have two windows Xp copies on the same hard disk, you will experience a slow performance in your system.
If you need to delete one Windows Xp copies, and leave only one, here is how you do it:
When you restart your system, and you get a choice of two operating systems, you should choose the one you want to keep installed on your machine.
Once the startup process is done, and your computer is ready to accept tasks to perform certain functions, you click on the "My Computer" icon and locate the hard disks, removable storage devices, and more.
In the hard disk box you should see two drive icons, like "C", "D". If the copy you installed later need to be cancelled, it must reside on the "D" part of the hard disk.
This is because the "C" is where you initial copy of the Windows Xp resides, and it is the one you want to keep installed as the only copy on your computer.
The way you should get rid of the "D" copy is to format the "D" part of the hard disk. just right click it, and choose format. This will delete the Windows Xp copy you don't need.
In summary, you can have two operating systems installed on your windows Xp machine, which will offer a choice of loading one of two operating systems.
The good thing is that you can cancel one, and leave the other, and your computer keeps running.
Feb 01, 2011 | Microsoft Windows XP Professional
Hello Sir, I purchased Acer Aspire 5745G two weeks ago. Yesterday My brother installed Fedora 12 and Windows7 was already instlled in it... Acer Customer Care Service suggested me to use Windows7 only. So...
The problem is with your Windows Boot file "bot.ini file" This file can become damage, corrupted or deleted for a number of reaons, (here seems the installation of Fedora 12) and id usually brought to your attention to by an error message befoe booting windows, the same message you are facing. there are two ways of removing it. 1-You can format your OS and re install it. or 2- repair your windows using the windows OS Cd.
Nov 15, 2010 | Acer Aspire One PC Notebook
Will not run xp pro i'm stuck in 2000 mode mother board is ak77 pro 133 vt8233 will not run xp pro i've been told im pretty much sol. Is this true?
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
Cheers!
Mike
Jan 07, 2010 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Boot loader for fedora8 & windowsxp
Boot a Linux Rescue Disk and Re-Install Grub with the command. "grub-install"
mount /dev/your_boot_partiton /boot
grub-install --root-directory /boot /dev/hda
The Boot Sector is Stored on the first 512 Bytes of the physical Disk.
Sep 23, 2009 | fedora Linux Operating System
Install Fedora
If you are using 2 hard drives then install Fedora to the 2nd drive. When you boot up it will ask you which os you wish to boot into. Hope this helps.
Dec 22, 2008 | Microsoft Windows XP Professional
How to install XP in toshiba Satellite L45-S7423 laptop
You can access Vista disk management (right click on computer from the Start Menu > Manage > Storage > Disk Management) and shrink your current partition and create a new one. Then install XP on that new partition. This is if you want a dual boot of both XP and Vista.
Nov 17, 2008 | Computers & Internet
Consistent hard Drive BOOT ERROR after an upgrade to MSNV-939 motherboard
You can run a disk manager for your drive however, I'll bet you will find its windows boot.ini. It may read just fine for a dual boot system but think about this. Windows can get confused real quick. I'm talking about the regestry. Take the time and do a fresh install of your Linuex and than re-install windows "clean install". I'll bet everything works out just fine. When 1 changes MB's there is a whole list of new drivers PCI devices loading into windows. Your system will run better with one copy of drivers for your new board and windows will not carry a list of old drivers and PCI devices of your old board.
Oct 17, 2007 | Mach Speed (MSNV-939) Motherboard
Consustently get "DISK BOOT FAILURE _ INSERT SYSTEM DISK AND PRESS ENTER" message
use xp sp2 bbootable disk and simply run a repair installation it should heal your system
Microsoft Windows XP Professional for PC Logo
139 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
