Question about Sony WEGA KE-32TS2 32 in. HD-Ready Plasma Television
My Sony KE-32TS2 32'' TV keeps turning on and off
My Sony KE-32TS2 32'' Plasma tv keeps turning on and off. The technician told me it needed a new x-sus board and wanted to charge me $600 to do it. I bought one myself and still have the same issue. I even tried the y-sus board but no luck. It turns on for a second, the fan starts, the picture comes on and then it turns off right away and repeats indefinitely.
  • Anonymous Mar 16, 2014
    no sync on any inputs
  • 148 Answers
I agree, you have a powerboard problem. I've wrote this so you can diagnose this yourself, and perhaps, fix it yourself!
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcdMy Sony KE-32TS2 32'' TV keeps turning on and off - 2_bing.gif and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel2_bing.gif monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
Posted on Feb 02, 2010
  • 4 Answers
Hello Sir,
Your power board is defectived. Need to replace new power supply for your TV.
Posted on Sep 04, 2009
Sony KE-42TS2U. Nothing happens when the TV is
Seems some thing wrong with power input plug or may be with power board in side the tv. first confirm with different power socket.
Oct 07, 2013 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
I need a replacementnbase stand for a sony wega 42" plasma tv
Contact Sony with the model number to see if available or not, other than that Google the model number with base to see what comes up, last resort might be to look on EBAY.
Dec 10, 2012 | Sony WEGA KE-50XBR900 50 in. HDTV-Ready...
My Sony KE-P42M1 Plasma TV, has sound but no picture, the picture was coming on if you play with the remote but now its just blank. The TV is 5 years old. Any idea's?
it is posible to repair ...but it is very coastly . you are going to repair this plasma same price u will get new plasma .it is my best idea
Nov 14, 2010 | Sony KE-P42M1 42 in. Plasma Television
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Apr 01, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Power turns off right away
Its correct, Sony is no more selling plasma and I think many companies has already shut plasma production and CRT TV as well.
All TV manufacturers are busy in LCD TVs.
Jan 17, 2009 | Sony WEGA KE-50XS910 50 in. HDTV-Ready...
KE-42XBR900- SYSTEMS SHUTS DOWN ON ITS OWN
Replace the G board. I had same issue and Sony accidently sent me two boards. I will sell the other for $450
danmathieu@aim.com
Jan 28, 2008 | Sony 42XBR900 Television
Apple TV and Sony KE32TS2 Plasma TV
That's weird... I just looked at the back of my set Sony KE-32TS2U and it has a DVI port.
Nov 18, 2007 | Sony WEGA KE-32TS2 32 in. HD-Ready Plasma...
61 Inch Sony Plasma KE-MR61 needs to be repaired
Ke series makes that an early plasma TV
that old will probably be throw away or requires the replacement of the whole printed circuit of the TV
or power source
if chinese built that circuity may no longer be available
any local mobile TV repairer can check that TV out for you
check out the internet for sony corporation south africa
for parts availability
Mar 30, 2017 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Sony WEGA KE-32TS2 32 in. HD-Ready Plasma Television Logo
1,197 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
