Question about Frigidaire 24 in. FDBS956CC Stainless Steel Built-in Dishwasher
Water not draining after last cycle
When the washer shows it is done the dishes don't seem to be very clean and there is quite a bit of mirky water at the bottom
  • Arlo1965 Dec 08, 2007
    I found out what my problem was.........Pilot error........I replaced my garbage disposal last week and did not remove the knock out for the dishwasher drain. I took it out and it works like a champ now. Thanks
    Arlo
  • Anonymous Jun 05, 2008
    do to a flood my frigidaire dishwasher was disconnected by the plumber and set a side for about 5 weeks,the plumber hooked if back up and now after the cycle is finished the bottom of the tub is full of water.the only change made is now the drain hose is coming through the bottom of the cabinet and hooked to the sink drain where as before the drain hose came through the top of the cabinet i believe my dishwasher is 8 years old but this is my first problem
  • 833 Answers
Arlo, sounds like your pump isn't working right. You should hear it pushing water about during the wash cycle. If not, check the filter screen on the unit first. Next, we'll have to talk about what to check ... pump motor or timer.
Posted on Dec 08, 2007
  • Robert Hirst Dec 09, 2007
    Arlo...you didn't tell me that!!! I'm grinning here.
Water will not drain completely/or at all from unit.machine cycles thru all stages, dishes seem clean but lots of water left in botton of washer.
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Dishwashers
Dishes not clean after running. Dishes and glasses have a white residue on them after drying. Water is turned on and seems to ok. When I open the washer after the wash cycle starts there are several...
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps... Please post back if you need more informatiion.
Daniel
Nov 26, 2010 | Bosch SHU9925UC Built-in Dishwasher
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher does not drain completely
Check your main drain system where your finally connect to let off the dish washer water.
Apr 10, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Mucky water after cycle complete
poss a blocked drain or a backe feed from the sink remuve drain hose and check.
Nov 13, 2008 | Dishwashers
Water is not circulating. machine runs full cycle but when opened, soap is in a mushy lump, not dispersed or dissolve, and dishes are still soiled
When was the last time you cleaned you drain filter? That should be done routinely .. If that's clogged then the the sediment from other cycles just gets redistributed on your dishes.. You might also check the washing arm that spins for debris or clogs.. Try cycling it without any dishes a few times to see if all the water drains out after a cycle.. That will help you identify if its a drain problem or if the system needs other service.. Hope that helps !
Aug 18, 2008 | Frigidaire Dishwashers
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Frigidaire 24 in. FDBS956CC Stainless Steel Built-in Dishwasher Logo
113 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
