Question about Dometic RM2652 Refrigerator
Fridge will not work in gas mode.
I have a Norcold fridge and it runs as long as we are plugged in to electric but as soon as we switch to lp mode it dont work. Can you tell me why!
  • 636 Answers
You mat have to clean the pilot light and the ignition lube. Spiders like to build nests in the tubes which obstructs the proper gas flow.
Posted on Sep 04, 2009
Why does my Norcold fridge on Jayco 2014 come on but does not get cold?
if chimney cold check heater element and LP for flame if chimney hot unplug thermistor from control board let run if gets cold replace if not either bad board or cooling unit
May 16, 2014 | Thetford Norcold RV Cooler/Freezer
Fridge will not work on AC mode. AC is present into fridge.
There should be a code appearing on the display. If you are not getting any 12V to the Fridge your fridge will not function. You may also want to check for any blown fuses inside the electronic board assembly. ">
Aug 30, 2013 | Norcold Inc Norcold 1200LRIM Refrigerator
Norcold fridge berps and display says No flame
check for a gas shut off inside the fridge cabinet as well. You may have to bleed all the air out of the lines before the fridge will get gas. either keep trying or run stove burners to make sure gas is working. Also look for debris inside the burn chamber near the thermocouple/pilot light.
I had rust fall from the exhaust tube and block the burner area. Cleaned it up and it works fine now.
Mar 25, 2013 | Thetford Norcold DE0051 Refrigerator
Refridge not working
Even if your plugged in, you'll have to confirm you have 12Volts DC going to back of fridge at connections, behind vent cover. Is the upper board on front of fridge lighting up when you turn it on? Could you also give me model number off fridge to help guide you better ? Model # should be on inside of fridge.
Dec 08, 2011 | Rv Motorhome Dual Co & Lp Gas Alarm...
Norcold model 1200LRIM. Unable to select AC or LP mode. Auto is only option. Fridge frequently quits in Auto mode. No error codes. Display just goes blank. Battery connections are good; voltage is good....
Try to unplug it from the battery a few hours and then plug it back in and see if you are now able to select the AC or LP mode. There has been a recall on the 1200LRIM, The defect is a potential cooling unit leak caused during AC electric mode operation. Click on the link below to read more:
http://www.texastriallawyer.com/norcold/index.html
Nov 21, 2010 | Thetford Norcold RV Cooler/Freezer
I know this is a vague question. (trying to help out hubby) I am currently at work, however, our norcold elect/gas fridge/freezer in our mallard camper stopped working properly. the lp gas light is lit,...
Don't be despirate.
You need a little more knowledge ... I'm here to give it.
Your RV refrigerator requires 12 volts to operate; on gas or on electric ... it needs 12 volts - period.
Now then, your frig will get 12 volts from your 'power converter' AND/OR your battery. You do have a battery in your unit, correct? If not - why not? Get one. (Your power converter cannot provide all the 12 volts you potentially require in all circumstances. It is there to charge the battery, which CAN supply all the 12 volts you require. The converter can probably put out 15 amps - your battery can put out 100 amps or more (@ 12 volts DC). Relying only on the converter for your 12 volts will cause over heating and will eventually destroy the converter. Batteries are about $100.00 - converters are about $300.00.
As you know, your frig will run on gas if you are plugged in or on generator ... that allows your frig to get the 12 volts required to run the controls.
What about electric operation? If you are plugged in or on generator, you can run on electric because your Norcold has 12 volts from the converter and/or battery.
Whats going on? Your absorbtion type refrigerator requires a heat source to boil the ammonia mixture to create "heat removing" (you can't really cool anything ... only remove the heat from it!) You can heat the ammonia with a flame or with a electric CALROD. However, the control panel that drives the whole operation runs of 12 volts.
You have a battery and generator and are plugged in and it still doesn't work? You will find a fuse on the control panel in the compartment accessible from the outside of your unit. Check/replace the faulty fuse and you will be back in business.
I hope this helps you and hubby with your Norcold Frig. Thanks for your interest in FixYa.com. If you found this solution to be helpful, please vote. Thanks
Aug 02, 2010 | Refrigerators
I just replaced the converter in my motorhome and everything works but the fridge won't work on house electricity, only gas ???
The old converter may have blown out the control board for your 'fridge. This is quite common if the voltage exceeds 15.5 volts, and when there is a ripple voltage (AC voltage component) riding on top of the DC voltage.
Gas / LP mode is the default for this fridge, a fail safe mode.
You can find the service manual for your fridge here.
Jul 08, 2010 | Dometic RM2652 Refrigerator
Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
Sep 27, 2009 | Thetford Norcold RV Cooler/Freezer
Was camping all weekend... frigerator was fine, brought it home and plugged it in and all electrical works fine, but frigerator is dead. none of the lights come on (auto, off, gas) no cooling. How can we...
This can be a problem on the control board or in the control switch, you better check this first..
For clarification may I know what model/maker that you have?
Thanks
Aug 31, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Mar 24, 2009 | Dometic NDR 1292 Refrigerator
Dometic RM2652 Refrigerator Logo
304 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
