Question about Hitachi 60UX57B 60" Rear Projection Television
Double picture Hi I have Hitachi 50UX27k, the pictue is out of line (actully its just the color red tha is out of line). I have pressed the majic button several times and nothing works...
    President:
  • 788 Answers
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
You will also want to replace the white heat sinkdouble picture - 2.gif compound that is on the heat sink, just scrape it off, then clean the surface with alcohol. Then apply a thin coating of fresh heat sink compound, if you do not do this important step the new IC's will not last long as the old compound will act as an insulator to the heat transfer.
I would suggest that you contact a service center in your area for a complete diagnosis and repair, as this type of repair can get a little tricky. But if you want to repair the set yourself, just remember to be careful. The capacitors and CRT’s can hold a charge and may shock you.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Sep 04, 2009
Testimonial: "Thanks for the input"
My red wont line up left to right , picture is good in the middle of the screen but not on the sides
The R,G,B colors alignment wouldn't line.That mean ur tv have a problems known as a convergence problems,it dead.The tv convergence board require the 2 STK convergence ICS and some or all it resisrors to be replaced,to solved the convergence problems.The shop will cost $300-350 for parts and labors.
Jul 06, 2010 | Hitachi 46F500 46" Rear Projection...
There is too much red in the television
your red convergence circuit is defective and requires attention
Apr 28, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Double picture (like a red halo)
First, it you have an orignal Hitachi remove go into the customer menu and look for convergence--if the set will not adjust (red or blue) in some direction--you have a bad Convergence chip--this set uses two--check the model number and confirm it to me. Both chips and any resistors around them that are bad need to be found and replaced--you can buy both of the chips on Ebay for less than 13 dollars!
Usually, just both chips need to be replaced and the set adjusted-most shops will charge 300-400 for this kind of repair--I have done hundreds of them here for 200-250 total cost. If you cannot do the repair look in your area for someone who can--any good tech can do this repair in your home in about one hour--if a shop says it has to "go to the shop" keep looking.
Now is the slow time of year for TV repair shops so look around-200-250 is a good investment and you cannot replace the set for this amount--this is about the only problem this set ever has!
If you have questions or need help--reply to this post here.
I do this here for free so if this helped you take a minute and give me a vote here.
SD TECH
Sep 04, 2009 | Hitachi Televison & Video
Hitachi 57'' rear projection tv has double images on both sides.
tv looks in the center and have double and multiples colors . majic focous do not fix t
Jul 13, 2009 | Hitachi Televison & Video
Hear a click when turning on, but the red light, no picture
Please make sure that the video source is on and that the source input on the TV is set properly. I am thinkig that the TV is working properly but has no input signal to display.
Feb 26, 2009 | Hitachi 60UX57B 60" Rear Projection...
Majic focus lines very broad
Undue the calibration! It sounds like the dynamic contrast is up too high.
Jan 03, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Double picture on left side with red projector on Hitachi 55UX58B
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 20, 2008 | Hitachi 55UX58B 55" Rear Projection...
Pictue is dark as hell
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Oct 27, 2007 | Hitachi 65F59 65" HDTV
Hitachi 60UX57B 60" Rear Projection Television Logo
100 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
