Question about Kitchen Ranges
My oven was purchased in Houston, Texas, but installed in Colorado Springs, the oven worked for a while, but will not ignite the gas in order to heat the oven. I had Decor check the oven, but they do not have a solution, but to by another oven. There are not parts for this oven.
    Brigadier General:
  • 5,158 Answers
What is the make and model number
robert
Posted on Sep 04, 2009
MY LG LP1111WXRY1 PORTABLE DOES NOT BLOW COOL CONTINUOUSLY. IT BLOWS COOL FOR 60 SEC THEN IT QUITS. WHAT CAN I DO WHERE TO TAKE IT IN COLORADO FOR REPAIR?
here you go
LG Repair in Colorado Springs, CO ' uBreakiFix
https://www.ubreakifix.com/locations/coloradosprings/lg-repair
LG Repair with Fast Turnaround & Quality Repair Service Guaranteed! Call (719) 528-7054 & Schedule your LG Repair Today!
LG Locate Repair Provider ' LG U.S.A
www.lg.com > Home > Support > Repair > Locate Repair Provider LG Locate Repair Provider : Find your nearest LG repair service provider.
LG Service ' Repair Center in COLORADO SPRINGS, Colorado (CO ...
yp-usa.com/lg-service-repair-center-colorado-springs-colorado-co-usa/ Oct 8, 2016 - View LG Service ' Repair Center Phone number, Address, Working hours and Customer Care Contact Numbers in COLORADO SPRINGS, ...
LG and Samsung Appliance Repair ' Peak Appliance
www.peakappliance.com/...repair-colorado-springs/lg-and-samsung-appliance-repair/ As the Number 1 rated Appliance Repair Company in Colorado Springs we have you covered when it comes to your appliance repair needs for LG and ...
The Best 10 Appliances & Repair for 2017 in Colorado Springs, CO ...
https://www.yelp.com > Colorado Springs > Local Services > Appliances & Repair Best Appliances & Repair in Colorado Springs, CO - Service First Appliance Repair, Colorado Springs Appliance Repair, Springs Appliance Repair, Appliance LG LP1111WXRY1 Google Search
Jul 17, 2017 | LG Heating & Cooling
Microwave parts in houston
you must search in the yellow pages in Houston, however you can get very easy by www.repairclinic.com or http://www.marcone.com/applianceparts.aspx
God bless you
Nov 18, 2013 | Cuisinart CMW-100 Microwave Oven
Long preheat & strong gas order. Sometimes the oven will heat up & sometimes it wont. The broiler does not heat up at all.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Mar 11, 2011 | Frigidaire FGB24L2A Gas Single Oven
The broiler and the burners all light but the oven doesn't.
If the glowbar is light up then you have a circuit and all components are working. So Houston why don't we have ignition? Today's new fangled ovens use silicone carbide ignition. The oven safety valve has a bi-metal inside it. In order for it to open and allow gas to flow the resistance in the circuit must change. As that glowbar heats up it changes the resistance in the circuit. If it can pull 3.5 amps or better then that bi-metal will open allow gas to hit the burner. That is yall's built in safety feature. If a glowbar looks real dim and takes a while to come on if at all then it is weak. Whirlpool also has another type of oven that uses a safety valve with a thermocouple attached to it. A pilot light is on all the time on these and no power is needed to operate this stove. Over time the thermocouples cooper-nickel tip will wear out and won't hold the oven safety valve open. Other variations of this is a standby pilot and electronic spark pilot and a flame switch added onto a safety valve. Newer models use a computer board along with AC power to fire the igniters and DC power to open the distribution valve. Your broiler is working so I am sure your stove ain't got the DSI ignition system and you have not mentioned anything about a pilot light so I am assuming you simply have a weak glowbar.
Video:
More here
Oven codes and other stuff HERE
Feb 02, 2011 | Whirlpool Ovens
My kenmore gas oven is not heating. I can see that
Because of the way those ignitors work, they can heat up and still not turn on the gas... Change the ignitor and your oven will work again.
Check out this tip that I wrote about this problem..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 02, 2010 | Kenmore 92680 / 92681 / 92682 Electric...
GE Gas Range Over Won't Heat
Hello, Yes this is going to be the bake igniter. If you remove the lower panel in the oven you will see the bake igniter. It may still be working when you switch on the oven but it is not getting up to the correct temp in order to ignite the gas. Replace the igniter and you will be all set. If you have any other questions please feel free to comment. Good Luck! Mike
Oct 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My Gas stove takes over an hour to preheat sometimes.
Would be helpful to know brand and model. However, most gas ovens use a glowbar mechanism that regulates the amount of gas released into the oven. The glowbar also ignites the gas (and usually stays on all the time the oven is on). Often, the glowbar fails to heat up sufficiently and, as a result, doesn't allow the oven to release sufficient gas. If this happens, you may also smell small amounts of gas in the kitchen. The glowbar is hot enough to ignite the limited amount of gas being released into the oven. This is probably why the oven heats up but heats up very slowly. It's also possible that the heat being experienced in the oven is being generated from the glowbar itself without any gas being ignited. If this is the case however, it is unlikely that your oven to get very hot at all.
The way to test to see if they glowbar is failing is to test the amperage traveling to the glowbar when the oven is on. You can do this using a "clamp on meter" (purchased at any Home Depot or Lowes). Depending on the particular kind of glowbar you have, it should read above a certain amperage (in my case the reading was 2.7 amps and it should have been between 3.2 and 3.7 amps). I ordered a new glowbar from www.appliancepartspro.com and installed it myself (very easy). It fixed the problem. Here is a link that explains it pretty well (http://www.appliance411.com/faq/gas_range_ignition_systems.shtml#glow). Hope this helps.
Jul 25, 2009 | GE Spectra JGBP35 Gas Kitchen Range
GE SPECTRA JGBP35 Gas oven
Solved a similar issue. Sounds like your glowbar igniter is shot and needs to be replaced. While the glowbar is glowing, it is not heating up sufficiently to release gas into the oven. The heat you feel in the oven is actually from the glowbar and not from ignited gas. Replace the glowbard. Here is what I recommended to someone else:
"Would be helpful to know brand and model. However, most gas ovens use a glowbar mechanism that regulates the amount of gas released into the oven. The glowbar also ignites the gas (and usually stays on all the time the oven is on). Often, the glowbar fails to heat up sufficiently and, as a result, doesn't allow the oven to release sufficient gas. If this happens, you may also smell small amounts of gas in the kitchen. The glowbar is hot enough to ignite the limited amount of gas being released into the oven. This is probably why the oven heats up but heats up very slowly. It's also possible that the heat being experienced in the oven is being generated from the glowbar itself without any gas being ignited. If this is the case however, it is unlikely that your oven to get very hot at all.
The way to test to see if they glowbar is failing is to test the amperage traveling to the glowbar when the oven is on. You can do this using a "clamp on meter" (purchased at any Home Depot or Lowes). Depending on the particular kind of glowbar you have, it should read above a certain amperage (in my case the reading was 2.7 amps and it should have been between 3.2 and 3.7 amps). I ordered a new glowbar from www.appliancepartspro.com and installed it myself (very easy). It fixed the problem. Here is a link that explains it pretty well (http://www.appliance411.com/faq/gas_range_ignition_systems.shtml#glow). Hope this helps."
Jun 24, 2009 | GE Spectra JGBP35 Gas Kitchen Range
The oven doesn't work ,the ignator doesn't light up. no gas coming
The technical jargon is,.....:
In order for your gas oven to work this is what has to happen: 1. when you turn on the oven, the range sends 120 volts to the glow bar igniter. 2. as the igniter heats up (and starts to glow) it starts using more electricity. 3. when the electric use reaches a set amount (say 3.2 amps) the range knows the glow bar igniter is hot enough to ignite the gas, so it then releases gas through the gas safety valve. 4. when the thermostat tells the oven controller that the temperature has been reached, the control cuts power to the igniter, cutting the amp draw down, causing the safety gas valve to close. 5. process repeats to hold oven temp until you turn off oven.
So,..........the solution is:
most likely your oven igniter burnt out. Find your model number, usually on the range frame just behind the lower drawer or broiler drawer (depending on if it is a self clean gas range or not) and order the correct igniter and replace it.
Nov 02, 2008 | Kitchen Ranges
GE Spectra XL44
Easy to install you just have to remove the racks and the bottom of the oven. Call a local appliance store with the model # and ask for the ignitor.
Sep 15, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
11 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
