Question about SMCWIPCAMG Network Camera
Cannot see video from WAN
Hello
my network is an airlink101 router and a linksys router when the linksys is contacting internet directly and SMC camera is connected to airlink
from inside the network(airlink) i can see video, but from the other network(linksys) i cannot see videa, i can login just cannot see the videa, its black from and computer on network, same if i try to connect to the camera from the internet, its working on UPnP mode, both routers are set to UPnP enable, if anyone has an idea please help
thanks
  • yhoash Dec 08, 2007
    never mind i solved this problem alone
    i just disabled UPnP and using regular port forwarding
    seems like airlink has a problem with UPnP
  • 107 Answers
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Posted on May 08, 2010
  • 34 Answers
Be sure that both routers firewalls are accepting connections on the port that you are using for the camera.
Be sure that the port is being forwarded on both routers too.
Be sure that the gateway is the right one.
If you are sure, please check again.
Posted on Jun 14, 2009
It was working fine until ive reset my linksys wrt54g, and i did my setup again, but i dont get any internet connection, my linksys is using a cable to my pc. please help
When you resetted your linksys router, chances are, the setup for WAN connection was lost. You can try these steps:
1. Connect the internet directly to your pc. If your pc was able to browse the internet, move on to the next step. If not, you'll have to contact your ISP for the settings of your internet connectivity.
2. Connect back the internet to the WAN port of the router, and connect your pc to the router's LAN port.
3. Open the router's page in a browser (the address usually is 192.168.1.1, username is admin and password is admin)
4. If your router has a setup wizard, run the setup wizard, because it usually clones your pc's mac address.
Hope this helps.
Mar 06, 2011 | Linksys Wireless-G WRT54G Router
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Using the SMC100 Barricade as a Wireless Access Point
use the wrt310n router as the router for the internet (where dsl modem is connected) then just connect the ethernet port (not wan port or internet port) of the SMC to the ethernet port of wrt310n
Oct 31, 2009 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Apr 19, 2009 | Linksys Wireless-G Broadband Router
Continues lost of connection using router
- Kindly make sure you already configure the required ports of emule to your router.
Mar 14, 2009 | SMC Barricade N Draft 11n Wirele Router
Using Wireless + PPPoE at the same time kills router. SMCWBR14-G2
From your description, I am assuming you have a direct ethernet connection from an RJ45 connection in a jack in the wall. If this is the case, then you would just need to purchase a wireless router (linksys, D-link, netgear, etc). Connect the ethernet connection from the wall to the routers internet or WAN port. You will need to access the routers firmware configuration and set it to connect with PPPoE, so get your username and password from your ISP if you are not sure what it is.
You will be able to continue to have the PC plugged into the router with an ethernet cable, and then run the laptop with a wireless connection, just be sure to configure the laptop with the security key if applicable.
If you were using a software PPPoE connection on your PC, quit using it. Just set your network adapters on both computers to DHCP, and you should be good to go.
Hope this helps
Chris (ziraffa)
Jan 14, 2009 | SMC (SMCWBR14-G2) Router
Two router home network problem
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via 192.168.1.1. Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Dec 22, 2008 | SMC2804WBR Wireless Cable/DSL Broadband...
Smc289wbr wireless could it be a cable problem
re-configure the router properly and get the right details from your isp.(internet service provider)
Oct 13, 2008 | SMC Barricade g SMC2804WBR Wireless Router
Cannot get internet and WiFi when I connect to smc6624M
ok you do the reconfigure the linksys routerand give the wireless enable in the both smc and the linksys also .
Jun 01, 2008 | SMC (SMC7004AWBR) Router
How do I configure my SMC Turbo router for a Cable Internet connection?
In the routers web-interface, click on login (password would be either 'blank' or 'smcadmin') -> Home network settings -> click on WAN settings -> Dynamic IP address -> more configuration -> click on clone MAC address and save the settings.
Feb 19, 2006 | SMC Barricade 7004 Router
SMCWIPCAMG Network Camera Logo
136 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
