Question about Briggs & Stratton Garden
The mower will start to move and go about ten feet and quiet pulling
  • 62 Answers
Hydrostatic transmission needs oil
Posted on Oct 27, 2009
The mower can be pushed,but it locks rear wheels.If you pull it a few feet it frees up again. The rear wheels are locking up. Motor runs great.When you move the steering arms there is a resistance lik
I assume that this is a hydraulic drive. These usually have an isolating rod which has to be pushed in or pulled out, depending on model, before manually shifting machine. This opens a bypass valve which makes the drive ineffective. Check that this rod, which will be low on the rear of the machine, often on the left hand side, has not been moved. Try moving it and see if this is the difference.
Aug 26, 2014 | Garden
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
The pull start cord will only move about 3-4 inches and then it stops and then cord stops, Troy built- Briggs/Statton 21 inch self-propel lawnmower.
The mower's drive shaft may need to be lubricated. If you turn the mower over and try to move the blade by hand (with the mower off, of course) does it move, or is it hard to move? If it's hard to move or it won't move at all, lubricate the shaft by squirting some WD-40, 3-In-1, or other lubricating oil onto the drive shaft where it meets the chassis of the mower. Squirt enough oil to cover the circumference of the drive shaft, then try to spin the blade again. It should at least spin a little bit now. Squirt some more oil and spin the blade again, until the blade spins easily. Then turn the mower back over and try to pull the start cord -- it should pull normally now.
Jun 05, 2011 | Troy Bilt 5.5hp Self Propelled Mower
I have a Troy-Bilt Briggs and Stratton 675 series lawn mower. The pull cord is stuck and will not move. I can lightly pull the cord repeatedly and the cord slowly allows me to pull more but if I release it...
Take the plug out and try to move the blade. If the motor won't rotate, the problem might be with the motor and the cord can't move because of it.
Gary
May 19, 2011 | Garden
Hello I have a husqvarna YTH22V46 riding mower that doesn't want to move. I have changed drive belt in the spring and it worked fine but now mulching leaves the drive has slowed. I have replaced the belt...
Bleed the air out of the transmission. Pull the lever at the rear of the garden tractor and disengage the transmission. Then fire it up and press forward pedal for ten seconds, then reverse for ten seconds. Do this a total of three times, then re-engage the transmission. I had the problem you did, but after reading you had questionable success changing the belt, I read the freaking manual and saw that you should do this when it's brand new. I figured it couldn't hurt, and voila, I could pull inclines again and go much faster.
Nov 14, 2010 | Husqvarna Garden
Mower starts up fine then moves fine for about 20 feet then slows up and eventually stops moving. Also, the hydrostatic relief valve will not allow the mower to move freely
The wheels are adjusted too low causing the mower to cut the lawn very short. This will cause the blade to jam and eventually stall. Adjust the wheels so the deck is higher off the lawn and try again.
Mar 19, 2010 | Garden
Blowing fuse
youve got a short in the wireing ,prob right at the clutch peddle switch
Mar 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
56 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
