Question about Micro Innovations (USB755FW) Serial Adapter
Where may I obtain a driver for usb/firewire combination cardbus?
Driver for usb/firewire combination cardbus?
I have a new ASUS G73SW-A1 laptop with no firewire port. Can I add a firewire port. Can I install a Belkin Firewire adapter into the cardbus? Does it even have a cardbus? There is some kind of card slot on...
You can add a firewire card to on of your existing PCIMCI slot.
Please see, as an example
HERE
You may purchase these cards online at nearly any electronic/computer shop.
May 04, 2011 | Computers & Internet
Got old toshiba laptop to use as portable graphic runs windows98
Your old Toshiba laptop most likely does not have a firefly port.
The only way to use your firefly device on the Toshibe is to purchase a firefly PCMCIA adapter card and plug it into the Toshiba's PCMCIA slot and install the card driver.
Please click on this link for details and prices for this adapter :-
http://www.firewire-1394.com/cards-firewire-laptop-notebook-cardbus.htm
Jun 14, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
I have a combo cardbus card, when i put it in to the slot it turns the laptop off.
The combo cardbus is creating some type of conflict to your router and that one is a sign of compatibility issue so better if you just have the card replace....
Nov 09, 2009 | Adaptec 2-in-1 Combo FireWire & USB 2.0...
How do i connect a Samsung SC D372 digital cam to a Gateway computer
For your camcorder, your computer will need a simcard slot or you will have to order a cardbus with IEEE1394 connections.
FireWire IEEE-1394 PCMCIA 2 port CardBus Inserting the firewire IEEE1394 cardbus being inserted into the laptop cardbus port ... Make the connection between the FireWire CardBus and your DV camera, ...
www.usbgear.com/Firewire_PCMCIA_cardbus/
May 07, 2009 | Samsung SC-D372 Camcorder
Putting video from hi-8 camcorder to a dvd
FireWire IEEE-1394 PCMCIA 2 port CardBus Adapter - Increased speed ...Inserting the firewire IEEE1394 cardbus being inserted into the laptop cardbus port ... Make the connection between the FireWire CardBus and your DV camera, ...
Apr 09, 2009 | Samsung SC-D372 Camcorder
Iogear gpu 202 cardbus not working with mac powerbook osx 10.4.11
Try the TechGear USB 2.0 cardbus. There are some available on eBay for $10.00. Item number is 250394104416. I bought two for older Titanium 15" PowerBooks, one on 10.4.11; one on 10.3.9. The cards works perfectly with no software drivers. I just inserted them into the PC slots and they work fine. In one case, one computer had a bad factory USB 1.1 slot, so the card does well for extending the comuter's life. The card included a CD with drivers for older versions of Windows and Mac 10.1 and Mac 10.2. I would NOT install drivers for newer systems.
Feb 27, 2009 | IOGear Cardbus Card GPU202 Serial Adapter
How to get my PC recognize the Panasonic NV-GS15
Solution A: make sure you are using the correct cable for what you are doing (eg USB for webcam and importing photos and Firewire for transferring video footage
most desktops have firewire plug in them but laptops don't usually
to get a firewire plug in a laptop you need a PCMCIA to Firewire Cardbus (ask your local retail store for one or buy one on ebay etc.)
after that put the cardbus in your PCMCIA slot and restart
then go to Windows Movie Maker and press "capture from video device"
hope this helps!
James
Jan 25, 2008 | Panasonic NV-GS15 Mini DV Digital...
Quantum Maxtor Serial Adapter
Though I suspected that I already knew the answer to your question about a source for drivers for the Maxtor 1394 CardBus Adapter, I wanted to research this in order to be able to provide PROOF that my answer is correct. As a result, I've now spent more than two hours researching this issue for you... As it turns out, the drivers you have requested are actually EMBEDDED within Windows itself, and have been ever since the release of Windows 98 Second Edition. They are listed within Windows as "OHCI 1394" drivers, which is another designation for FireWire / IEEE1394 device drivers. According to the Seagate / Maxtor Knowledge Base, there are NO downloadable drivers for the Maxtor 1394 Cardbus Adapter, and none have ever existed. The software originally provided on the CD in the retail package for the Maxtor 1394 Cardbus Adapter did NOT include drivers, which I'll explain in more detail later... As a general rule, when installing the Maxtor 1394 CardBus Adapter into a system for the first time, you insert the PCMCIA card into the Type II slot while Windows is loaded, NOT while the system is shut down; after inserting the card into an empty Type II CardBus slot, you should then hear a tone indicating that Windows has detected a device in the slot. The Add New Hardware Wizard should then load, and you might be prompted to insert your Windows CD into your optical drive, though this should NOT be necessary if you've previously installed any other FireWire devices on the same system. You can download the Installation Guide (in .PDF file format) for the Maxtor 1394 CardBus Adapter from either of the following links: http://www.seagate.com/staticfiles/maxtor/en_us/documentation/ins tallation_guides/1394_cardbus_installation_guide.pdf http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000 041641.pdf Simply right-click one of those links, and choose the "Save As..." option to download and save the Installation Guide to your Desktop, or to another folder where you can find it easily... The following links should help you to learn more; the first link explains the reason why drivers are NOT available for download for the Maxtor 1394 CardBus Adapter: http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_adp.php?p_faqid=831 The next link describes a known problem (and the solution) when the Maxtor 1394 CardBus Adapter is installed on some IBM Thinkpad laptops: http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_adp.php?p_faqid=1959 The next link describes the hardware and software requirements for installing the Maxtor 1394 CardBus Adapter: http://seagate.custhelp.com/cgi-bin/seagate.cfg/php/enduser/stx_adp.php?p_faqid=762 As I've previously mentioned, the original software (on the CD-ROM) provided with the Maxtor 1394 Cardbus Adapter were the "MaxTools" utilities (which I have NOT been able to locate for download); they were NOT actual hardware drivers for a Windows OS... Well, I hope this solves the mystery of the "missing" FireWire drivers; though I don't recall ever needing to load third-party drivers for ANY FireWire devices I've installed in a Windows system, I wanted to be able to PROVE to you (and to anyone else who reads this in the future) that the drivers are already embedded within Windows, and that they are NOT available for download. As long as you use a supported version of Windows (all versions beginning with the release of Windows 98 Second Edition), you already have the drivers available, though Windows will probably need to extract them from the Windows CD, if they haven't been loaded onto the system previously. Good luck with this; let us know if you have any problems installing your FireWire card. I don't think that is likely to happen, as long as you follow the steps in the Installation Guide. You might want to create printouts of those Seagate Knowledge Base pages (or copy them to your hard drive, or at the least, bookmark the individual links) for future reference.
Apr 01, 2007 | Quantum Maxtor Serial Adapter
Did i just get ripped off?
Did you install the latest drivers for this device? Download and install the latest dell drivers and firware for the cardbus controller. Make sure you are using dell drivers, not microsoft from windows update.
Nov 11, 2006 | SYBA 4 Port Combo CardBus/PCMCIA to USB...
Micro Innovations (USB755FW) Serial Adapter Logo
142 people viewed this question
Top Micro Innovations Computers & Internet Experts
micky dee
Alun Cox
Are you a Micro Innovations Computer and Internet Expert? Answer questions, earn points and help others
