Question about Cell Phones
HTC Advantage (bought in Taipee) has reseted and now asks for its factory original code .... I tried ''0000'' and all the like... to no avail. Help Fenix
I have a htc g1, I already received my unlock code from tmobile but when I put a foreign sim card in, it just goes to the home screen instead of asking for unlock code, how do I get to the unlock screen so...
try hard reset to original factory settings will get back. at it will ask for sim unlock code when you enter am invalid sim.
This actual video will help and make it easy for you to understand on how to Hard Reset your phone.
just follow this link : http://www.youtube.com/watch?v=AE5SYVjXK_w
Good luck.
Jun 25, 2011 | HTC G1
I set the password years ago, forgot it. Tried the procedure in the manual to dump it and reset it. Doesn't seem to work. Is there an original password that will remove the parental control?
Hello, try 0000. Failing that try a factory reset in menu. The code for that,if it asks is 0000 there is always a way of resetting, even if it means getting a technician in to do it.
Mar 28, 2011 | Televison & Video
How to unlock HTC advantage 7500, forgotten the password
You may try default phone and security code to remove it
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Sep 19, 2010 | HTC Advantage X7500 Smartphone
I have an lg cookie KP500,and have locked the phone.it asks for the pin code but have forgotten the pin code.can u help?
By default it's 0000.
OR try this :
1. Insert original sim card and turn your LG Cookie on.
2. Enter 2945#*750#
3. A menu will pop-up. 4. Press Factory Reset.
May 30, 2010 | Cell Phones
There is a password on my behold, but I forgot so how do I reset?
if you changed the factory preset code, which is usually "0000", then you must have your service provider reset the code to the original for you.
Jul 23, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
Apr 15, 2009 | Nokia 6300 Cellular Phone
Htc p3400 phone lock
Try usual unlock codes 0000 or 1234 or 00000 or 12345
Jul 30, 2008 | HTC Touch P3450 Smartphone
My lcd tv is locked how do i unlock it
i called the help line and they said the only way to fix this was to call best buy and order a new, original remote for the television
the number the help line gave me was1-888-237-8289
May 02, 2008 | Insignia LCDTV26 26 in. Television
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
