press and hold power and volume buttons to reset the device,pair it with the radio or phone and start over,when doing anything with voice you need to get rid of ALL background noises,including radio and air,(windows down),
Press the Voice Command key, and when prompted, say turn prompts off. To turn Voice Command on, press the Voice Command key and say turn prompts on. I hope that you have found this information useful, and if I can be of further assistance, please let me know. Thank you for using fixya!
When you try voice command and you cant speack any thing or sound is not clear than time out will appear
If your voice is clear than your command are not found...
Just try other word
To make a handsfree call from the bluetooth device (Voice dialing) - Briefly press the PWR/END button to activate “Voice Command”. You will get the best results if you first record the voice dialing tag through your Headset.
Hi
The way to stop this is go to voice commands, settings, and one option should say call alert, and you can set it to ring only, caller ID+ring, or name repeat, and set it to ring only.Hope this helps,Joe
Voice command is activated by the side button that is alone (right side if your facing the phone's screen) when the phone is closed. I don't know how to prevent the phone from doing that, but I do know how to make sure the phone does not say "Please say a command."
Menu Settings and Tools (Far right icon) Tools (#2 on the list) Voice Commands (#1 on the list) Hit settings, which is going to be the right bumper button (above the CLR key) Go to prompts (#5 on the list) Mode (#1 on the list) It will be currently set on prompts, which is why it says "Please say a command." You can either set it to readout or tones only. Tones produces a short beep. Readouts only displays text (no noises). Being that you have your phone on silent, I assume you want readouts.
That will at least prevent stop the phone from making random statements in your pocket. Hope this helps.
I had the same problem with a Motorola bluetooth. I had to return it to the store because it was defective. It wasn't a problem with the phone it was the bluetooth.
lg g2 voice command not working
