Question about GE Televison & Video
Cannot get sound...must have pressed some button when I was trying to remove "closed caption"..which I did...
  • 26 Answers
You probably turned off speaker ,press menu botton and go down to sound menu scroll down and turn speaker on.
Posted on Sep 04, 2009
How do you remove closed captioning? I have a 4yr old 50" plasma tv. Today the captioning just popped up and I can't figure out how to get rid of it
Hi
1* Use the CAPTION button repeatedly to select Caption Off, EZ Mute, or On.
* EZ Mute shows the selected captions option (if available on program) when the TV sound is muted.
2* Press the ENTER button to save.
Caption Tips
* Not all TV broadcasts include closed caption signals.
* Sometimes TV stations broadcast four different caption signals
on the same channel. By selecting CC 1 to CC 2, you
can choose which signal you view. CC 1 is usually the signal
with the captions, while Another mode might show demonstration
or programming information.
* Your TV might not receive caption signals normally in the following
situations.
OK.
Jul 13, 2011 | LG Televison & Video
A black rectangle appears in the bottom half of the screen. The rest of the picture is fine, the sound is fine. The box goes away if i press the menu button - but it comes back again. What is wrong?
Do you have a cable/satellite box connected to this tv?
Try this first it sounds like you have the closed caption turned on by accident.
On the remote press the MENU button.
Use the navigation keys to move the selector to CC and press OK.
This should bring up the Closed Caption sub menu.
Ensure that the closed caption is set to OFF
Thanks,
Robert
Feb 26, 2011 | Vizio M220VA 22 in. LCD HDTV
Can't turn off closed captions or find option to do so please helphelp
hi,
u can remove the closed caption optoin by the following setup.
1.Press the CC button on the remote to display the current Closed Caption setting.
2.Press the CC button repeatedly to choose from the four Closed Caption options (CC
Off, CC1, CC2, CC Mute). select CC off.
3.When finished, press the STATUS /EXIT button to remove the menu from the TV
Dec 26, 2010 | Philips 32PT6441/37 32" TV
How do I turn on the closed captions
hi,
u can switch on the closed caption option for ur tv by the following setup.
1.Press the MENU button. Press the up or down button to select "Setup", then press the ENTER button.
2.Press the up or down button to select "Closed Caption", then press the ENTER button
3.Press the ENTER button to select "Closed Caption". Press the up or down button to select "On", then press the ENTER button.
4.Press the up or down button to select "Caption Mode", then press the ENTER button
5.Press the up or down button to select caption mode you want, then press the ENTER button. Press the EXIT button to exit the menu.
ok
Dec 22, 2010 | Samsung HLN437W 43" Rear Projection HDTV
How the **** do i take off captions off my philips tv
Hello
Press CC button on the remote to display the current Closed Caption Setting.
Press the CC button Repeatedly to choose from the four Closed Caption Options [CC OFF,CC 1, CC 2, CC MUTE].
When finished press the Status/Exit button to remove the Menu from the Tv screen
From the above said four Caption options just select as your need. OK.
Nov 12, 2010 | Philips 32PT6441/37 32" TV
My tv has a black square in the middle of the screen.how do i remove it
thats your closed captioning. on your remote, there should be a button on your remote to remove the closed captioning or to change the captioning type. Look for the "C.C." Button. press it. the closed captioning type will change. press again and again untill there is no text or it says "off or None"...
Hope that helped.
Aug 14, 2009 | JVC AV-32D305 32" TV
How do I remove the closed captioning box on my tv
There should bea button marked caption. Try pressing that
May 27, 2009 | Quasar SP-3235 32" TV
I need help with removing captions
This information was found on the Magnavox website http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&grp=TV_GR&session=20090602222010_68.190.209.25&ctn=27MS343S&mid=Link_UserManuals&hlt=Link_UserManuals in the owners manual on page 20. If this information does not solve your problem. Try calling Magnavox customer support at this telephone number 1-800-705-2000. Give them the model number of your television and tell them about the problem you are having with not being able to turn of the closed caption feature. I hope this helps you solve your problem. 1Press MENU to show the on-screen
menu.
2 Press VOL+ or VOL- until SET is highlighted.
3 Press CH+ or CH- repeatedly to
highlight CLOSED CAPTION.
4 Press VOL+ or VOL- to display the
CLOSED CAPTION menu.
5 Press CH+ or CH- to select the
closed caption you want (OFF, CC-1,
CC-2, or CC-MUTE). CC-MUTE sets
the TV to show closed captions when
you press MUTE. The TV volume will be
disabled until you press MUTE again to
restore the sound.
6 Press VOL+ or VOL- to confirm your
selection.
7 Press TV/AV/EXIT to remove the
menu.
Apr 23, 2009 | Philips Magnavox 27MS343S 27" TV
Can't Turn off Closed Captioning on Sanyo 36 in TV AVM-3658
Hi Hfrohman, This may sound crazy, but, press and hold the power button on the TV while unplugging it, continue to hold power button for 60 seconds or more. Release it and plug TV back in. Sometimes that will clear the settings.
I hope that works for you.
Jun 26, 2017 | Sanyo AVM-3658S 36" TV
Cant get rid of captions
look on top and behind of the monitor you will find buttons for your TV then follow this steps: The Setup menu lets you configure the TV to fit its surroundings and your preferences. To access the Setup menu, press MENU, and then select Setup from the Main Menu.closed caption options are: CC Setting Lets you choose the way closed captioning information appears on the screen. Off No captioning information displayed. On Always Captioning information shown always, when available. On When Muted Displays captioning information, when available, whenever the TV?s sound is muted by pressing the MUTE button. The captioning information is not displayed when the sound is not muted. Make sure all of the options for closed caption are off press exit and you are good to go.
Aug 23, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
27 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
