Question about Apple iPod classic 6th Generation Digital Media Player
Red x on screen
Went to the support page and did what it said but cannot get my nano into disk mode. My computer does not even pick it up when plugged in. And my warranty is done
    President:
  • 392 Answers
Try repeating the process a couple of times..here's the procedure again. Slide the hold switch on and off a couple of times and then let it rest on off position.press and hold menu and center buttons till you see a silver apple logo on the screen.then connect to system and it should be detected in itunes as ipod in recovery mode.restore it!
Posted on Sep 04, 2009
The screen went white and at top of screen said "disc mode". Wouldn't respond to any of buttons and wouldn't charge when plugged into computer. Went back to normal on its own after 3 days and...
Welcome to Fixya
Looks like the software just hanged-up on you. Try to reset the Ipod by following the procedures below.
1st option:
Turn the Hold switch on, then back to off.
Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
2nd option (Disk Mode):
Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
Press and hold the Menu and Select buttons until the Apple logo appears
Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode. If at this point you still have the white screen, restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory settings).
Note: Do not disconnect or eject the iPod until the store is totally done. After you think it's done, wait another five minutes.
Thank you
Dec 05, 2010 | Apple iPod Nano Video 8GB Purple (5th Gen)...
Stuck ipos in disk mode
Plug it into the computer, and in the ipod's main screen, uncheck the box that says allow disk mode. Hope this works!
Aug 31, 2009 | Apple iPod nano 3rd Generation
My ipod nano 8GB,just went blank even resetting it will not help,i thought it was a battery problem but it is not even recognised by the computer.any solution to this?!
try charging it ...if that doesnt work try getting it into disk mode-here's how..slide hold button a couple of times to off and on and then when hold is off press and hold menu and center buttons till you a see a silver apple on the screen then connect to PC and it should be detected...restore with itunes....that shud work....
Aug 27, 2009 | Apple iPod nano
Locked iPod
You can unlock your iPod nano in two ways:
A Enter the combination on iPod nano by using the Click Wheel to select the numbers
and pressing the Center button to confirm them. If you enter the wrong
combination, it flashes red. Try again.
A Connect iPod nano to the primary computer you use it with, and iPod nano
automatically unlocks.
Note: If you try these solutions and you still can’t unlock iPod nano, you can restore
iPod nano. See “Updating and Restoring iPod Software” on page 50 for more
information.
Sep 03, 2008 | Apple iPod nano
Ipod nano
Well try to format the ipod when its in disk mode.. go to my computer find the ipod right click and format
then you need to restore it with itunes
heres a guide
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
May 02, 2008 | Apple iPod nano 3rd Generation
My nano won't restore.
Try putting the ipod in disk mode by pressing the center and play buttons after resetting it (by holding down the center and menu buttons). You will know it is in disk mode when it shows a check mark on the ipod screen. Then plug it into your vcomputer and format it using windows.
After you format the ipod, try disconnecting and reconnecting to the computer and restore and see if that fixes your problem.
Jan 30, 2008 | Apple iPod nano
Ipod nano 2nd generation won't mount
Could be a hardware problem. Sometimes ipods will not connect to a computer even when everything else is working fine.
Jan 27, 2008 | Apple iPod nano
IPod nano 3rd generation 4GB got screwed in the middle of an update
Mine wont let me stick in in disk mode??? whats up with that?
Jan 25, 2008 | Apple iPod nano
Ipod nano 1st generation trouble! help!
Sounds like a corrupt hard drive.
put it into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
Find it in "my computer", right click it and select format. Choose the FAT32 option and hit OK.
Once its done, restart your computer and plug in your pod. Start itunes and it should automatically reinstall the ipod firmware.
Nov 30, 2007 | Apple iPod nano
Nano screen is all white, but works otherwise?
It might be the LCD screen. You can take it in to an Apple store and see if they can replace it. Or, you can take the riskier option and try to change the screen yourself (not recommended). It doesn't sound like you'll be able to fix it without taking it in.
Nov 02, 2007 | Apple iPod nano
Apple iPod classic 6th Generation Digital Media Player Logo
191 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
