Question about Electronics - Others
Erase/remove all protection
Transcend JF220 - With fingerprint protection
The security on this is really annoying. Can I disable and remove the protection so I can use it as a 'normal' USB key?
Who to delete jf220 fingerprint
Posted on Apr 20, 2010
First get onto control panel and select "add or remove programs" then look for it (alphabetic) after all you is just remove it.... That's my guess..
Posted on Sep 04, 2009
Pendrive write protection unable to remove
download Active kill disk from following link.
http://software.lsoft.net/KillDiskSuiteFree-Setup.exe
this will erase all data and protection files
Jul 14, 2014 | Transcend 8Gb Jetflash 300 Usb Flash Drive...
Hp envy of unlock passeord
Which operating system ???
CMOS (Complementary metal oxide semiconductor) refers to the battery-powered, semi-conductor chip located on an HP computer's motherboard.
It is where the BIOS stores important information regarding the PC's system configuration. CMOS is required for an HP laptop and its hardware to run stably.
Sometimes, however, it is necessary to clear CMOS, such as if you lose your BIOS password or your BIOS is corrupted.
Clearing CMOS on HP laptops varies depending upon the model, but for a lot of laptops, the process simply requires removing the battery for a short period of time.
Power down your HP laptop. Remove the AC adapter and any other peripheral devices. Turn over the computer so that the bottom side is facing up.
Ground yourself, either by touching a piece of unpainted metal or by wearing an anti-static wrist-strap.
Locate the battery. This will vary depending on your laptop's model, but it is usually located on the back, near the rear of the laptop.
Review your laptop's documentation to find the battery, if needed.
Many newer models require that you remove the battery by releasing or holding down one or two latches, then gently pulling the battery out.
Some models may instead require that you unscrew the battery from its compartment.
Leave the battery out of the compartment for at least 30 minutes.
Do not attempt to turn on the computer and do not touch the battery within that time.
Some HP laptops may require you leave out the battery longer to clear CMOS, others might take only 10 to 15 minutes to reset.
Ground yourself, then put the battery back into the HP laptop.
Snap the battery latch into place or screw the cover back on, if necessary.
Removing a Bios - CMOS Password
http://www.dewassoc.com/support/bios/bios_password.htm
Disable Fingerprint on an HP Laptop
Many HP laptops include a fingerprint scanner to enhance the security of your computer.
When the fingerprint scanner is enabled, the computer requires a fingerprint scan to log onto Windows.
Disable the fingerprint scanner if you do not need or want this feature.
With the fingerprint scanner disabled, you can log on to Windows using a password.
You can enable the fingerprint scanner anytime you need to.
Access the Device Manager on your computer.
Select "Control Panel" from your computer's Start menu.
Click "Hardware and Sound" and then click "Device Manager."
Find "Personal identification devices" in the "Device Manager" list.
Click the "+" sign next to "Personal identification devices."
This opens a list of all of your devices.
Click on "Validity Sensor."
Select the "Driver" tab at the top of the properties window and click "Disable" to disable your fingerprint scanner.
The button changes to "Enable" and you can enable the fingerprint scanner at any time.
Click "OK" to exit out of the window.
Jun 27, 2013 | Computers & Internet
I have an ibm t43 laptop that got fingreprint protected, how do i remove the protection
In Windows, in the settings section of the Fingerprint Control Center, uncheck Replace windows logon with fingerprint protected logon. In the Fingerprint section uncheck the Power-On Security section if the user has fingerprints enrolled there. You do not need to uninstall the software unless you wish to.
Thanks
Mar 27, 2011 | IBM ThinkPad T43 Notebook
Acer aspire 8935G+ disabling fingerprint bio protection
since the system still ask for the finger print and you want your partner to be using it and there is no how your partner will using it since protection is there, it is advice that you should uninstall it, for it to work for your partner. thanks
Jun 14, 2010 | Computers & Internet
I have transcend 8gb pen drive which is write protected ..how to remove it
Any user use USB anti virus program?
If yes try to this,
uncheck "Disable writing of any usb devices".
Dont use this software? any one (maybe your friends use this software and disable write protection in your pendrive ) contact your friends.
OR
download USB anti virus program from google search, and try to uncheck disable writing option.
Mar 17, 2010 | Transcend (589307) Media
How to use password instead of fingerprint to logon
How to disable fingerprint reader
Nov 12, 2009 | Microsoft Computers & Internet
Hi ,i having 1GB of flash drive of Transcend company.for some unknown reason that showing "write protected ,disable it to use" message is coming.i tried several ways but not succeeded.how to disable that...
I sense that your usb memory is equipped with a physical write protect switch that you may have overlooked. Locate it, switch to the "non-writeprotected" (unlocked) mode and everything should work normally. Good luck!
Jun 03, 2009 | Kingston 4GB Secure Digital High Capacity...
Disable the fingerprint sensor on lenovo R61i
If you don't plan on using it anytime soon the easiest way is to just remove the software from the ADD / Remove Programs section in the Control Panel.
Let me know if you have any problems.
Mar 04, 2009 | Lenovo ThinkPad R61i Notebook
Transcend jetflash 2GB no detecting
ny Transcend jet flash 2GB fingerprint not recognized, any help fpr me pls to format or to find any solution for this problem...
thanx
Basman
Nov 01, 2008 | Transcend (589307) Media
Electronics - Others Logo
1,253 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
