Question about SimpleTech Computers & Internet
I wiped my entire external hard drive....now it doesn't even show up on my computer.Can i get it formatted again? It isn't recognized by the computer
  • 3,153 Answers
Yes you can if its electrically OK
Start, Control Panel, Administrative Services, Computer Management, Disk Management.
it should be listed in there and you can use that panel to format etc.
Make sure you let it have a drive letter.
Also a few USB tips below.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Posted on Sep 04, 2009
Dvd recorder hard drive not recognized when used as an external
Open Start menu
Click the right mouse button on Computer
On the pop out menu click on Manage
In the left hand menu click on Disk Manage
Your drive should show here if it is plugged in.
Delete all partitions
Now create a partition, format it how you want.
Mar 21, 2014 | Hitachi Computers & Internet
My wd p/n wd8200me hard disk is recognized by me computer as USB mass storage device. But i wont show up in my computer. how can i make it work again?
Try this hard drive on another computer to see if you can back up your data.
Then format this hard drive using your computer. When you format the hard drive your data will be lost.
Sep 01, 2011 | Western Digital 320GB MyBook External USB...
I have an external hard drive made by Gigaware. When plugging it in, the computer recognizes it as mass storage device but will not show up in My Computer. The external drive is on and spinning. Any...
If you have not used the external hard drive before, you will have to go into your drive management and initialize your drive and possibly format it. The fact that your computer recognizes it is a good sign. It means that the external drive is working properly and the computer recognizes that the external drive is there. I have an short paper I have written describing how to use the drive management utility in windows. It is too long to post here. I can either post part of it or you can give me your email and I will send it as a MS word attachment so you can have the entire paper.
I hope you find this helpful Brian
Here is the part I can post here:
Using Disk Management Utility
Disk management utility will help you see all the drives that are connected to your computer, including internal hard drives, CD or DVD Drives, and removable storage like USB sticks and external hard drives. Using this utility, you can check for attached drives that are not visible in windows when attached to your computer. You can also format drives, change drive letters, mark a partition as active and delete partitions. A word on caution about using the Disk Management Utility: This utility can cause destruction of data. If you are not sure of what you are looking at and uncomfortable with using this utility you should consult with an advanced user before making any changes to drives using this utility.
Right click on you "My Computer" Icon
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive this is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken.
Dec 25, 2010 | Computers & Internet
Computer wont recognize external hard drive
try to format the external HDD using command prompt..... type "cmd" in start & search box and hit enter... command prompt will be opened... Now type "format X:" where X=your external hdd drive letter.... if it does not format then right click on my computer icon> goto manage >select Disk management> select the external drive> right click and delete partition > again right click and select create partition > again right click and select Format drive.....
this will fix the issue....
Apr 20, 2010 | Western Digital My Book Essential Edition...
Hello! i got a problem with my external hard drive. My 4G flash is recognized but my 320G hard drive is not recognized in my desktop. I tried to plug the 320G hard drive in my laptop and it was recognized....
The external drive needs to be initialized from your PC. To do this, right click your My Computer and choose Manage. At the left panel click on the Disk Management. The list of available drives will show on the right.
Right click on the drive and select create partition (primary partition). After you've selected your partition , now you need to format the hard drive. Choose quick format. Right click again on the partition you've just created, now select "Format" and select NTFS. Click ok and it will guide you until it is finished.
If you need further assistance, just let me know.
Oct 12, 2009 | Buffalo Technology Computers & Internet
I can't access the hard drive
You will need to initialize it from the Disk Management. To do this, right click your My Computer and choose Manage. At the left panel click on the Disk Management. The list of available drives will show on the right.
Right click on the drive and a window will popup. Select create partition (primary partition). After you've selected your partition , now you need to format the hard drive. Choose quick format. Right click again on the partition you've just created, now select "Format" and select NTFS. Click ok and it will guide you until it is finished.
Oct 03, 2009 | Maxtor MaxLine Plus II 7Y250MO 250 GB SATA...
Externals not recognized by computer.
Go to your control panel open up 'administrative tools' Open Computer management, then choose disc management instead of device manager. Make sure that you have the drives pluged in and connected before you do that. All connected drives formatted or not that are in working order should show up under disc management. If they are not showing up they are not compatable. Make sure that they are marked as active and format them if they need to be formatted. Do so by right clicking on the drive in the disc management window.
May 12, 2009 | Hitachi External 20GB Mini Slim Hard Drive...
External hard drive not recognized
Try it in another PC and if it does not work i guess your hard drive might be infected by a virus and needs to be formatted. if it works contact me again.
Dec 14, 2007 | Computers & Internet
Computers & Internet Logo
283 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
