Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
My Philips 60PP9202 has blue wavy lines that comes up from the bottom. Also words and pictures appear 3D.
    Top Expert:
  • Philips Master
  • 14,553 Answers
Go into the customer menu with the remote and look for "convergence" if the red or blue will not adjust in some direction you have a bad convergence chip. This set uses 2 STK-392-120 chips---both need to be replaced along with any of the 6.8 ohm resistors around them that are bad--a bad resistor will be discolored or white in the middle.
With the back cover off the chips are located on two metal heat sinks on the large board on the left side (as you look from the back) and both will have the STK-392-120 number printed on them in white--the chips are black in color.
Most of the time you just need to replace both chips and adjust the set with the remote control. You can buy both chips for about 13 dollars on Ebay--if you can do this repair yourself you will save a lot of money!
Most shops charge 300-400 for this kind of repair---I do lots of them here for 200-250 including parts, labor and house call. Now is the slow time of year for TV repair shops--shop around--if they say "it has to go to shop" keep looking; any good tech can do this repair in your home and it usually takes about an hour.
I do not know how much skill you have but if you need instructions I will help you. This problem happens for a simple reason--the chips are about 2 inches wide and 1 1/2 inches tall with 18 pins each--the back of each is metal and a white grease is applied to each to transfer heat quickly to the metal that they are bolted to. After some years the grease dries out from the heat and one of the chips cannot move the heat fast enough and it fails.
IF YOU HAVE ANY QUESTIONS OR NEED HELP CONTACT ME BY REPLYING TO THIS POST.
I DO THIS here for free so if this has helped you take a minute and give me a vote here.
SD TECH
Posted on Sep 04, 2009
LINES AT THE TOP AND BOTTOM OF PHILLIPS MODEL NO. 60PP9202/17F
no lamp for this model, it uses three picture tubes but the three D looking picture is a convergence circuit problem and is fixable.
Apr 04, 2012 | Philips 60PP9202 60" Rear Projection...
I have model number 60pp9202 and the screen is mostly red and green and when words come up there is like a double image
Tv have any colors lines R,G,B mis alignments,have a colors shadows picures or a 3D pictures look alike?Yes?The tv have a problems known as a convergence pictures problems,it is dead and the problems.The tv convergence board must have to be repair like replacing like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv pictures convergence problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 30, 2011 | Philips 55PP9502 55" Rear Projection...
I have a friend with a Philips 60PP9202 TV, and she describes her problem as: "The top/bottom corner of the picture is kinda waved and the color is blue/red (3D like)". Would anyone have an...
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 15, 2010 | Philips 60PP9202 60" Rear Projection...
My Philips 60inch widescreen rear Projection the picture color is blue and red how can i fix it
Tv problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Philips 60PP9202 60" Rear Projection...
Blue & yellow stripe on bottom of screen at first now red and green like 3d
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Jul 08, 2010 | Philips 60PP9202 60" Rear Projection...
I have a Philips 60PP9202 60 in. Rear Projection HDTV-Ready Television. I do not have a remote for it, which I am going to purchase ASAP. When I press the up/down channel button on the TV it changes the...
Ur tv have a convergence problems.Ur convergence board the two convergence ICS,and some or all it resistors are dead.U know how to solders?U have soldering tools,and solders.Tries Websites like Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
May 10, 2010 | Philips 60PP9202 60" Rear Projection...
The picture is wavy on my 60inch philips hd tv
Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV may shut down after having the above symptoms.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 30, 2009 | Philips 60PP9352 60" Rear Projection...
A wavy line with 3 colors
this a convergence problem and the convergence IC's will need replacing along with some testing of resistors and or replacement
to have a technician come out to do this repair will cost about $300 - $350 to get this fixed
Dec 12, 2008 | RCA HD52W59 HDTV Projection Television
Tv convergence
You will need to have a qualified technician replace the convergence IC's and possibly 2 resistors
If you are somewhat experienced with properly unsoldering the old parts without damaging the pc board you can replace the IC's yourself.
Most Philips CRT Projection televisions use 2 generic number STK392-120. These are mounted on a large aluminum heat sink
and soldered to the bottom of the pc board
There are sometimes 2 or more resistors that may be burned most often these are 6.8 ohm 1 watt
These parts can be found at www.tritonicsinc.com be sure to get the "original Sanyo" or the Philips brand, do not use the cheaper versions that come from China
good luck
Supertek
tvservice1@sbcglobal.net
Mar 09, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
