Question about Dryers
Trying to replace timer 8299771. Can't find my
Trying to replace timer 8299771 on my Kenmore dryer. The replacement part I ordered was slightly different than the original. (model 60 instead of an 80) Can't find my manual. Need help wiring correctly as I have a blue wire left over. I have a place for it on new timer, but can't find one on the old timer. Dryer model is 111060882990. After reading through a couple forums I decided my timer, switch, or motor is bad. Dryer just doesn't work. I tested the timer per one of the suggestions on a site and I thought it was bad, so I ordered a reconditioned one to get me by. I tried hooking it up but it doesn't work. There's power to the door light, switch is working. Start switch is working (I tested with meter) I'm just wondering where the blue wire goes, and whether there's another switch I should try before testing the motor.
  • copelander Sep 05, 2009
    So the question now is, how do I test my motor? LOL
  • copelander Sep 16, 2009
    Okay, so I didn't know about the fuse. Good lord, I wish I had checked that first. Much easier to remove and test than the timer. Ordered one off ebay for $5. Slapped it in, and my dryer works again!!! Thanks AASC. You rule.
  • Dryers Master
  • 1,606 Answers
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Posted on Sep 04, 2009
Testimonial: "Okay that worked perfectly. Timer works. Unfortunately, so does the old one."
  • Mike Smith
    Mike Smith Sep 05, 2009
    Does the dryer not start ? If that is the main issue , then have you checked the thermal fuse ? It's a white piece with 2 wires connected onto it . This is mounted on the blower box . Usually , this piece is bad , when a dryer doesn't start . Would need the first 3 numbers of the model number to be able to tell you exactly where the fuse is and see which motor you have . ( you gave the last 7 but not the first 3 )
Kenmore dryer model # 110.79722800. everything works however the timer stop working. Need help
Posted on Apr 26, 2010
My dryer shuts off before its time and not heating
Model?
On a model I just repaired here's what I found:
Model: 110.69422801
Kenmore Electric
No heat. although sometimes it had heat for a short time. Suspected that the heating element was faulty (i.e. cracked heating coil). Nope. Checked hi and lower thermostats and both were good. Took apart timer controller. Found that the contacts inside were worn/burnt. Item is designed to fail. Slightly bent one of the contacts to make better contact and it is working. Ordered new timer/controller ($45 including shipping from "One Appliance" on line). Easy to replace. ALWAYS disconnect the power when servicing!!!
Mar 22, 2016 | Kenmore 800 6983 Electric Dryer
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Hi - My Kenmore top load stacked washer/dryer has a broken timer. The dryer just goes and goes until it's turned off. Can this be fixed?
you can order a replacement timer from either sears or they do sell a universal timer that can be installed by a service tech timer's run from $35-$90 depending on where you buy it
Jan 12, 2010 | Kenmore 80754 Top Load Stacked Washer /...
My Kenmore dryer heats as it should but the timer dosent move and the dryer stays on.
This is a common problem. Dryer timers are advanced by a motor that turns gears and moves the dial (and internal switching) forward. The timer needs to be repaired or replaced. More than likely the latter since most timers are riveted together and cannot be repaired (unless you're someone who can put a geared jigsaw puzzle back together without any instructions since they normally fall to pieces when opened). I have tried to repair some timers and have been marginally successful, but to have a piece of mind, order the part, have it replaced (wire for wire when the unit is unplugged from the wall). If the timers look different, it is still possible that they gave you the correct timer. Verify that the new and the old timers have the same letter and number markings on each of the wires.
It is best to label the wires as you remove them from the old timer with a piece of tape and a sharp pointed marker. That way there is no question which wire is which.
Hope that helps you.
Nov 03, 2009 | Kenmore Dryers
Buzzer wont quit
have you tried to turn the knob slightly at end of cycle to see if it would shut off? try that if it does shut off then replace your timer
Jan 06, 2009 | Kenmore 73952 Gas Dryer
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Jun 12, 2008 | Kenmore Dryers
Kenmore 110.64732400 Electric Dryer No Heat - Won't Shut Off
The stepper motor in those timers are prone to giving favorable readings when checked and go back to acting fruity when left to themselves. It's a sticking problem. Try taking the back off the control timer, usually you bend some tangs that hold it on straight, being careful not to overstress them and check the contact points. If they are burnt even slightly then take a file or emory cloth to them, making sure you keep them straight, don't round the corners. Then put the switch back on the head housing without the back on and plug back in. DO NOT TOUCH BACK OF TIMER WHILE PLUGGED IN. Run it through a cycle and see if the motor binds up. It may take a couple of times for it to do it if it's going to. If this doesn't work, then get back to me.
Jan 27, 2008 | Kenmore 64732 Electric Dryer
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Dryers Logo
264 people viewed this question
Top Dryers Experts
