Question about Sony Cyber-Shot DSC-S40 Digital Camera
My LCD Screen looks as if the colors are off. When i look at the image i want to photograph it looks fuzzy and colors like green and red appear. It looks as if it needs to be tuned
  • shelleylou Dec 20, 2007
    I have exactly the same problem, when i look at the image i want to photograph it looks fuzzy and the colors are red and green. When downloaded onto my computer they are fine but it is really annoying that I can't seem to fix this. I have had nothing but trouble with this camera since I had it for Christmas two years ago. Does anyone have a solution please.
If you cannot find a solution to your problem you may want to email He has good advice and good used parts at a fair price.
Posted on May 22, 2008
I have big screen (53") Soni TV that I had bought
Hi this is a common issue on this sets I also have the aame problem with my sony ,whats your model number?
Apr 18, 2011 | Sony Televison & Video
Color is messed up...very green looking screen, appears red colors appear green
Do you have extra hardware connected to the TV? If so, it could be a problem with the cable/connections.
Mar 07, 2011 | Proview Hx263 26 in. HD-Ready LCD...
Tv out of foucs
These procedures are from the owners manual, go into menu and then picture quality and then: Convergence The Convergence feature lets you adjust the TV’s three tubes. When the TV tubes’ images are precisely aligned, they create the color images you see on the screen. Over time, the picture can drift out of alignment (this is normal). If your picture seems fuzzy or has a yellow tint, using Convergence could correct this misalignment. Only one convergence is needed for all inputs, regardless of the signal format. Note: Make sure the TV has been on for at least 30 minutes (TV needs to warm up for best results) before starting Auto Converge or Red/Blue Centering. When you select the Convergence feature, a submenu appears with three options: Auto Converge Automatically aligns the projection lenses to self-correct color images. You’ll see flashing squares of color dance across the screen (this is normal). Note: After performing auto convergence, use the Blue Centering and Red Centering menus to fine tune convergence in the center of the screen, if necessary. Blue Centering Aligns the blue and green images to fine-tune the picture. Red Centering Aligns the red and green images to fine-tune the picture. Note: The ability to change channels is disabled when adjusting the convergence options. The TV must be tuned to a usable signal to converge the picture.
Apr 23, 2010 | RCA HD52W58 52" TV
I have red and green shadow on top and bottom of the screen.
Ur Convergence board is dead or deffective with the IC chip.
Aug 17, 2009 | Akai PTH5498 54" Rear Projection...
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
Dec 05, 2007 | RCA HD52W59 HDTV Projection Television
Distorted color on image
You might have "color filter" settings. Turn the digital filters off. Here is what manual at p72 says. "You can take pictures using digital filters. The filters consist of color filters such as red, blue and green, a soft filter that produces a fuzzy effect. Color filters Eight colors, black-and-white, sepia, red, pink, violet, blue, green and yellow, are provided for the color filters. When you select a color filter in the Digital Filter mode, the display on the LCD monitor is filtered with the selected color, and the pictures are taken in that color."
Mar 20, 2007 | Pentax Optio 555 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
85 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
