Question about Dell XPS M1330 Notebook
Dell XPS M1330 laptop doesn't boot just shows colored lines...
I have a refurbished Dell XPS M1330 laptop that has been acting up I changed the hard drive thinking that maybe the hard drive was fried but after a couple of days of it working again in went back to what it had done before. When it started acting up again i would turn it on and it would start to boot and bring up the safe mode options saying that i hadn't shut down my computer properly. Every time i tried using safe mode it would try and reboot again and send me back the the safe mode options. Now it doesn't even do that i can turn it on the light turns on but then its a black screen and a single green line starts to appear followed but several other multi-colored lines then they all fade to a solid white and then start fading in as purple and pink lines then green and the screen fades to black again. Is there anything i could do to fix this?
  • Dell Master
  • 2,404 Answers
Multiple problem issue going on here, with the screen having those lines popping up the way it is, the screen is definitely going to need to be replaced.
Hard drive is a more touchy issue. Not sure if you put a new one or a refurhbished one in the system. If it was a used one or refurbished one, I would suggest putting a new one in the laptop to be sure the hard drive is good and then reinstall the OS and put the drivers back on. That would be my suggestion.
The other thing to try would be to make sure your memory is good. If you have more then one stick, try each stick one at a time and turn on the laptop after inserting just one memory stick into the drive, and then repeat the process with the other and see if the laptop does the same thing each time, if it does then you know the memory is good, if you can get it to boot up into windows with one memory stick but not the other then you know one of the memory sticks is bad.
In fact try the memory swap first and then if that doesn't get you anywhere then try a new hard drive in the laptop.
If that doesn't get you anywhere then you know for sure the motherboard is bad.
Posted on Sep 04, 2009
My xpx m1330 will show up on screen. The laptop will show on external monitor. I have replaced the inverter. What do you suggest?
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 19, 2011 | Dell XPS M1330 Laptop, Crimson Red, Ultra...
My laptop is DELL XPS M1330. It heats up and then slows down the machine.
Inside your computer, any dust acts as an "insulator", preventing the heat "radiator" inside your laptop from dissipating the built-up heat. So, remove the dust:
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air.
Hold the can upright, and blow compressed-air into every hole and slot in your laptop.
Reconnect everything.
Apr 02, 2010 | Dell XPS M1330 Laptop
My dell xps m1330 will not boot up.it comes up on screen saying ''no boot sector on internal hard drive'' ''no bootable devices''it has had a new motherboard fitted by Dell.i'm trying to install xp pro
When it's booting, try to access the setup, aka BIOS. See if you can set CD/DVD as a booting option. As the top BOOT device. Then see if you can boot your installation CD. You may be able to format your drive during the installation - if the hard drive hasn't failed?
Nov 23, 2009 | Dell XPS M1330 Notebook
DELL XPS M1330 battery is not detected.
Boot to the BIOS and see if the battery status shows normally there. If it does, try uninstalling and reinstalling the quickset utility.
If the battery status doesn't show normally in BIOS then you will likely need to replace the battery.
Nov 13, 2009 | Dell XPS M1330 Notebook
Dell XPS M1330 Laptop can't boot to windows, when running express test, got error code 0F00:137B when re-install the vista, it stop at "Expanding files (0%)" long time ...
if you bought this from dell, use the restore disks that came with it starting with disk one. you wont be able to save your files bt at least you will have a usable computer. i have an XPS studio 16 and had to do the same thing.
Jun 01, 2009 | Dell XPS M1330 Laptop
Dell xps m 1330 starts fine but goes ...
Boot into Safe Mode and change the video resolution to the lowest resolution supported. Reboot the machine normally. The problem should have disappeared. From here you can readjust your display resolution to any higher resolution supported by the system if you wish.
Apr 01, 2009 | Dell XPS M1330 Notebook
Dell xps m1330
Well from what I have read in your description of the problem stated, there is no way to do this without replacing your hard drive. If you cannot remember or find your password for Boot of the Computer then you really have no choice, Or you can take the other way too and thats what you choose not to do and that's call Dell Custoemr Service and pay for warranty or a In-Service for your Dell M1330. There is really no getting around that, realistically also considering the fact that it appears to be a laptop it's going to be really difficult for someone to access the hard drive to replace the hard drive, So that really eliminates to one option and that is paying for a warranty with Dell or taking it to Geek Squad at your local Best Buy Retail Store...The cons of that take to a local retail store like Best Buy would be having to purchase a whole new operating system, paying for an agent to install new hard drive, reinstalling operating system, and the biggest part is will Dell now provide you drivers for your computer usually that will depend upon whether you get the Operating System that came with the Dell XPS M1330, if you choose to down-grade then you more than likely will be not elgible for Driver updates from Dell and will have to manually go to the manufactors and retrieve them one-by-one.
Oct 26, 2008 | Dell Inspiron XPS M1710 Notebook
Dell xps m1330
The M1330 is not in stock anymore at Best Buy, here is a choice of Dell laptop different models that can be purchased online.
Jul 29, 2008 | Dell Inspiron XPS Gen 2 Notebook
Dell XPS M1330 Notebook Logo
573 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
