DELL LAPTOP INSPIRION 1505. THE RED LITE BLINKS ONE TIME WHEN POWER BUTTON IS PRESSED THEN NOTHING.
    Brigadier General:
  • 3,614 Answers
If you can easily access the memory module of that laptop. Try to remove and clean contacts of the module, resit again into the slot.
Hope this
Posted on Sep 08, 2009
My Dell Inspirion 500 is stuck in hibernation mode. How do I wake it up?
Press the power button. If that doesn't work, press and hold down the power button and then reboot.
Oct 12, 2014 | Dell Inspirion IO232-05555BK 23" 2.5GHz...
Can't turn on my mini netbook inspirion - help
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell (INSPIRION MINI 10) Netbook
I have a Dell Inspirion E1705 which came installed with Windows XP. When I turn the computer on, I get the Dell Logo, then nothing except a cursor in the top left side. I tried booting from the...
try this, while the computer is off, press and hold the Fn key down then press the power button like turning it on.. it should say diagnostics boot selected. if it passes the test windows would have to be reinstalled. if it fails with error codes 0141, 0142, 0143 or 0146 then the hard drive has to be replaced.
Nov 11, 2010 | Dell Inspiron E1705 Notebook
Have dell inspirion 1501 no lites come on with power cord or with battery. nothing happens.
First try a different AC adapter, see if the system will power on.
If no change, then the failure is most likely the motherboard
Sep 25, 2010 | Dell Inspiron 1501 Notebook
My inspirion mini went into hibernate mode, and now won't restart. tried power button, light flashes 3 times but won't come on. tried pulling battery, no luck. Help?
Try this: Disconnect AC power, pull the battery, then press and hold the power button for 10 seconds. Release the button, replace the battery & AC, and try booting.
Mar 09, 2010 | Dell Inspirion Mini 10 Netbook
Hi, i have a problem with my Dell Inspirion 6400, after replacing Motherboard laptop won't boot up, after pressing power button, all 3 lights comes up (caps, num and scrl lock) and than back off, power...
I would hook up an external monitor to see if the laptop is working. If it is working fine then you must have a connection problem where the LCD plugs into the motherboard. I am willing to bet it is the LCD cable mot seated correctly. If it does not work on an external monitor try switching the memory chips one at a time if you have 2. Everything you mention indicates it is booting but no video. Good Luck Phil
Feb 21, 2010 | Dell Inspiron 6400 Notebook
Will not boot
click here to find the details.
you may also like to click here
Oct 02, 2009 | Dell Inspiron 1501 Notebook
Dell D600 battery
Sounds like your battery is bad.Some dead cells i tend to think
Aug 07, 2009 | Dell Latitude D600 Notebook
Inspiron 1505 speakers
The static noise may be a defect. If your laptop is still under warrent, contact dell for a warrenty replacement. I had the same problem with my inspirion. Sigmatel
Jan 24, 2009 | Dell Inspiron 6400 Notebook
Blinking Lights, Computer Wont Boot
If it's blinking 9 times then it's likely telling you one or more of the RAM sticks are in need of replacement. To check these, remove the laptops power cord and battery, then locate and remove, the cover for the RAM. Remove one chip at a time and try booting the laptop.
May 25, 2008 | Dell Inspiron 6000 Notebook
Open Questions:
26 people viewed this question
k24674
