Question about GE JTP27 Electric Double Oven
F8 on Ge JTP27 Whats wrong? - GE JTP27 Electric Double Oven
    President:
  • 1,382 Answers
The reason to get F8 is that the component failure that occured within the Electronic Range Control (ERC) effecting temperature processing circuits. Th perfect fix for this problem is to replace Electronic Range Control (ERC).
Posted on Sep 04, 2009
My top broiler won't turn on. Everything else works fine. I have exchanged the top broiler element with the bottom. So I know it isn't the element.
Could be wiring. Did it work before? Maybe, never connected? Could be demand of two oven's and or broilers at the same time exceeded the wire and circuit breaker capacity when installed and therefore were never connected.
Otherwise thermostat. Probably need appliance Tec or Electrician.
Mar 04, 2015 | GE JTP27 Electric Double Oven
I have a GE JTP27 double oven, now 12+ years old. For last 2-3years, having consistent problem with upper oven where, after oven heats up and/or starts baking, we suddenly get a beeping sound and an error...
Greetings,
its possible to be the oven sensor or something in the lock circuit...if all else fails then in the electronic oven control which costs 125.00 or there about...might find cheaper price on ebay or internet search The sensor about 40-60 dollars, but without a complete number its hard to be exact with a price or part list...if this is helpful ..please let us know or if I can be of more assistence. let me know...Bruce Denton
Dec 28, 2010 | GE JTP27 Electric Double Oven
GE Oven door lock 'engaged' while door was open and door will not close - how do I release the lock?
If your oven door has gotten bent or warped (maybe you rested something heavy on it...), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Dec 06, 2010 | GE JTP27 Electric Double Oven
Only bottom of the electric double wall oven works . lts a 1969 G.E.
If you can, test for power to the element in the top oven. If there is power coming to the element, it could be that the element is bad and can be replaced. If there is now power coming to the top oven there could be a more serious issue in a 40 year old oven
Nov 30, 2009 | GE JTP27 Electric Double Oven
GE JTP27 oven, ERC display completely lit, keypad
Yes, this is a problem with the ERC. You can buy a new one, or we can rebuild it for you.
Best Regards,
Bruce
www.fixyourboard.com
Oct 10, 2009 | GE JTP27 Electric Double Oven
GE Electric Range Model #JBP95A F1 and F7 Error Code
F1 is a common error code indicating a failure of the oven control board (aka ERC or EOC). Often these control boards have been discontinued, "no longer available" or are very expensive. We may be able to help and save you money.
We refurbish oven control boards at www.fixyourboard.com.
Mar 29, 2009 | GE JTP27 Electric Double Oven
Bottom oven gets extremely hot
It would appear you have a faulty thermostat that controls the temp. SUggest you get a new thermostat fitted.
Dec 08, 2008 | GE JTP27 Electric Double Oven
F 2 error code
F2 usually means that there was an over temperature condition in the oven cavity. A stalled cooling fan could be a related condition. The usual causes are:
Welded relay contacts. In this case you'll need a new ERC
Cooling fan stalled or blocked air flow to rear of unit.
High resistance inoven sensor leads or connectors.
Dec 22, 2007 | GE JTP27 Electric Double Oven
Faulty Oven Temp Sensor
The oven sensor pulls out once you remove the mounting screws. There is a plug to disconnect, just push and pull to dislodge any insulation and it will come thru the hole.
Apr 01, 2007 | GE JTP27 Electric Double Oven
GE JTP27 Electric Double Oven Logo
201 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
