Question about Music
It stays stuck on home screen.it was not plugged in to power protecter when the power turned off . My fostex vf-16 is a later model similiar to the mr16 model
I just purchased an MR8 that was stuck on the main screen with no response from any of the buttons. When I powered it up without a card it would say "No card, press enter", then I could operate most of the buttons but could not access the menu.
After closer inspection I found several pins were bent in the Compact flash socket. I pulled it apart (only took about 10 screws and two minutes) to have clear access to the CF socket and found a few pins were not only bent but broken loose from the board. I re-shaped the bent pins and re-soldered them to the board; these are very small so soldering experience is required.
After straightening and re soldering the pins, my MR-8 booted up normal and works great. For more info or pictures contact me (Mark) from my website contact link at www.e-lectronics.net
Posted on Jan 26, 2010
  • 62 Answers
Try going to the Fostex.com site and download the instruction book. It could be a small electrical fault inside the machine. If you've tried all then take it to a Fostex dealer and have the look at it. They're too expensive to play around with.
Good Luck
Posted on Sep 13, 2009
Manual for a Fostex vf-80 exp 8 track recorder
Attached is the online manual for the vf-80. Hope this helps! Fostex VF80 Owner Manual
Jan 17, 2017 | Fostex Music
MANUAL FOR FOSTEX VF-80 EX8
Attached is the online manual. Hope this helps! Fostex VF80 Owner Manual
I can only hear static through the headphones on my Fostex MR16. The recording sounds fine when I transfer to computer, but I can't hear myself playing.
They make headphone amps that will take a line level and boost it in volume until it can drive headphones. I'd get one of those, and plug it into any available "line out" or "rec out" on the back of your Fostex. Sounds like the D/A converter section that feeds the headphone output has gone bad, and my solution will get you around that.
Nov 27, 2013 | Fostex Mr16hd 16 Track Digital Recorder
Fostex LR-16 has locked up!
Does it come up with DRIVE INIT or does it go straight to please wait???
I had a problem like this when i didnt eject the media properly from my PC. It would not turn off and just said please wait..... until finally i switched it off waited 5mins then turned it back on. If you can get your PC/MAC to see the drive you should delet the file you uploaded. Did you put the stereo file in the "2mix" folder of directly into the project folder?? To be honest The Fostex LR16 is a pain in the ****!!!
Apr 25, 2012 | Fostex LIVE DIGI MIXER 16-TRK HD RECORDER...
I refcently purchased a MR16 Fostex it comes on lights up and shuts down . What is possibly wrong ?
Power supply. Most likely an electrolytic is failing. It may or may not show any signs of it. Other possibilities are bad solder connections, loose wire connections, or possibly a bad MOSFET if it uses a switchmode power supply. Also check the general construction to make sure nothing is shorting internally. Sometimes wires get pinched.
Feb 14, 2012 | Fostex Mr16hd 16 Track Digital Recorder
Fostex MR-16 Multitrack Recorder The screen
Hi, try and reset it. it will come back to normal.
Take care.
May 18, 2010 | Fostex Mr16hd 16 Track Digital Recorder
Hard drive failure
First thing is to open the unit and make sure the drive is connected. Sometimes cables get knocked off.
Next get a new drive... they are relatively inexpensive, like $69 or so and try it.
Take the old drive in your hand and snap your wrist to impart a spin to it. Then try the drive again... If it comes back to life, SAVE ALL THE DATA from it quick, and transfer to the new drive.
Dec 27, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
My new fostex mr8hd-cd 8-track recorder is unresponsive at times in the middle of a function...what could be the problem?
Is it plugged into a power socket with an anti-surge & anti spike adaptor to stop the small power variances. Try that and if it's not that go to the Fostex website and ask them just in case there is a small problem with your machine which is a very nice one indeed.
Good Luck.
Sep 13, 2009 | Fostex Mr 8hd CD 8 Track Recorder with CDr
Music Logo
124 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
