Question about Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Color fading on Sony 32'' Bravia KDL-32ML130
I have a 32'' Bravia Sony, model KDL 32ML130. Sometimes the color goes to black and white. If I switch channels it comes right back to color. Sometimes the color will return within 10 to 15 seconds. Anyone have similar problem or a solution?
SOURCE: Sony BRAVIA KDL-40S2000 color problem
you might had problem with the video switcher board. The A board.
Posted on Mar 07, 2009
  • 3 Answers
SOURCE: Cracked LCD Screen
its cheaper, and this is honest as it happened to me as well it's cheaper to buy a new tv.
Posted on Jul 20, 2009
milkburp
  • 416 Answers
SOURCE: KDL-32ML130 Sony Bravio 32' LCD HDTV motion blur
Logic board? Are you referring to the Main PCB (BU board I think). This issue is caused by the Timing Control board (T-CON). It’s the board directly on the panel that connects by LVDS cable to the Main PCB. Not sure if it’s a part you can purchase separate from the LCD panel, but give it a whirl… you never know. I hope this was of some assistance.
Posted on Mar 25, 2010
  • 586 Answers
SOURCE: 32 lcd sony bravia, will turn on but nothing
According to the symptom problem is not so critical, the software needs upgrade. Today i am doing same with another model with same symptom, although updating of software is not big deal for us but i will suggest you to please contact any sony service center or expert nearby, because we do this in routine but lot of things involve like, for software update you need original USB (1GB,2GB but not higher) of Sony, and do some changes after updating in data etc, Which will make it difficult for you, So i will suggest you get it to the nearest service center and they will get nominal charges of it.
Please let me know if yo need further assistance on comment column.
Thanks for understanding.
Posted on Nov 24, 2010
fredback99
SOURCE: Sony Bravia KDL 46V100 has only black & white picture-no color
I bought Sony Color Bravia TV 60 inch, moved with it Kenya, Africa, when i try to tune the color is not coming. I can only get black and white. Please anybody with idea on how to change it for Africa (Kenya). Model:KDL-52SS100. My e-mail. fredwagah21150@yahoo.com
Posted on Jun 04, 2012
I have a Sony Bravia KDL-32ML130. I turn on the tv and the colors are really red and the pictures seems like it's moving in slow motion. It does this with the Direct tv, dvds, and vhs. The sound is...
LCD Panel (screen) is defective and need to be replaced to solve this problem.
Click YouTube.com to watch similar problem in lcd tv that brought to my repair shop.
Thanks.
May 30, 2011 | Sony Bravia KDL-32ML130 32 in. LCD TV
Tip
Hi i have a 32" Quanta LCD display, when i turn it on the screen goes white then...
This is the basic guide that can be applied to most LCD flat panel TV.
By Bud Martin
First, try unplugging it from the outlet for about an hour to see if the TV will reset itself since the minute the TV is plugged into the wall, the power supply and processor will be running 24/7 and the EPROM can get corrupted by spikes and surges. Try using good quality surge suppressor to see if it will help if it happen often.
Look for burnt brown hot spots on the circuit boards, capacitors with leaking/bulging top or seals. Loose wires and connectors. Blown fuses.
Notes: We are dealing with high voltage that can kill you! so if you are not sure what you are doing, please have it fixed by the pro that has proper tools and safety equipment. Try to use GFI outlet and isolation transformer when work around the TV set and DO NOT DEFEAT THE GROUND PIN OF THE OUTLET/POWER CORD.
1) The power supply module (There are 4 regulated output voltages:- Standby 5vdc, switched 5vdc, 12~16vdc, and 24vdc).
The power supply converts the 120/230vac 50/60Hz into DC, then the high frequency (50~100kHz) switching circuits convert it back to AC but at high frequency which allows the power supply to use smaller and much lighter weight transformers (Ferrite core instead of heavy iron core), then this high frequency AC voltage is fed to the rectifier Diodes to get the DC output and filtered by DC filter capacitors that must have low ESR (Equivalent Series Resistance), if general purpose electrolytic caps are use, they will fail within a year or less due to high ESR.
The power supply has Standby 5vdc (5VSB, this is a MUST have before anything else will work, when this voltage is not present, there will be no any indicator light on the front panel) which is always on the minute the TV is plugged into the AC outlet, so it is on 24/7 and that is why the power supply will fail even though you may use the a TV not very often. It will see all the voltage spikes and surges 24/7.
This 5vdc is used to power the Processor and the Infrared remote receiver module which will be waiting for the command from the remote control or from the power switch, when the Power on command is received, the Processor will send the turn on signal (3.3~5vdc) to the power supply module (PSON pin) to the switch on the main 5vdc for the rest of the logic and Tuner circuits, 12~16vdc for the sound amplifiers (mostly Class D amplifier for efficiency and small size) and for the T-CON board (interface board between the LCD panel, some T-CON uses 5vdc, and the Logic board), and 24vdc for the Back lights inverter board (if there is no 24vdc then no back light).
Common failures:
Blown main AC fuse due to shorted out Diodes, transistors.
Bad capacitors leaking or bulging tops:
Shorted Diodes, transistors in the DC output side.
Testing the power supply output with dummy load:
24vdc testing: Disconnect the wires that go to the inverter board first. You can use two #1157 (using both Lo & Hi filaments by paralleling them at the base) car light bulbs connected in series so they can handle the 24vdc, this will put light load (about 70w) on the 24vdc output, the voltage out should be steady at 24vdc (+/-2v), if not, the power supply has regulation problem.
12vdc testing: disconnect the 12vdc TV load from the power supply board and attach one #1157 (using just the Hi filament), the 12vdc output should stay at 12v (+/-1v), if not, the power supply has regulation problem.
You should see the lamps go on when the TV power switch is ON and go OFF when the TV is powered OFF.
2) Main Logic board (It has Processor, Tuner, Sound Processor, Sources selector, Power amplifiers for speakers, interface port to the T-CON board for pictures).
This logic board sends out the turn on signals (3.3~5vdc) to turn on the rest of the Power supply module (Switched main 5vdc, 12~16vdc, and 24vdc), Inverter backlight ON (if no back light on command then there is no back lights),
Logic board supplies 5 or 12vdc to T-CON board B+ pin through switched transistor if T-CON board does not get the voltage from the logic board, you will get white/gray glowing screen without pictures.
Back lights Dimming (PWM) control signal.
3) Back lights Inverter board. Its job is to provide the drive voltage for the CCFL (Cold Cathode Fluorescent Lamp) to give white light for the screen.
This board is fed by the switched 24vdc (VBL) from the power supply module, it also get the Back lights on (BL on) control signal and the Dimming (Dim/PWM/) signal from the logic board. So for it to work, it needs 24vdc and the BL_ON signal.
Common failures:
Blown surface mounted fuses due to shorted transistors/ICs, Transformers.
Bad capacitors.
4) The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
5) LCD panel assembly to display pictures. The LCD pixels will block or unblock the back lights from the back of the panel to the front of the panel. This is the most expensive part of the TV, it will be more than the TV is worth.
As you can see, you must have all the above Voltages and signals for the TV to work properly. This may help you narrowing down the bad modules instead of buying the wrong module just to find out later that it did not solve the problem. Hope this will help you out.
Sound problem:
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
Inverter board connector: you can also see the Fuse 4A/160V
http://i.fixya.nethttp://i.fixya.net13ca788.jpg
Power supply connector:
http://i.fixya.nethttp://i.fixya.net78e0d9a.jpg
http://i.fixya.nethttp://i.fixya.net2fc510f.jpg
T-CON board: (metal cover shielding is removed to show the bd.)
http://i.fixya.nethttp://i.fixya.net0b5367e.jpg
Inverter board:
http://i.fixya.nethttp://i.fixya.netaf0a695.jpg
Logic board:
http://i.fixya.nethttp://i.fixya.net4bd108e.jpg
T-CON board is dead, no power or blown fuse on the board, screen turns WHITE, must see it in darkened room, otherwise you may mistaken it for failed backlight.
http://i.fixya.nethttp://i.fixya.net3a91b68.jpg
Bad T-CON board after warm up, you get lines, multiple pictures, strange colors blotches, etc.
http://i.fixya.nethttp://i.fixya.netd3cf194.jpg
Bad caps (leaking/bulging tops). Make sure to replace bad cap with good cap such as PANASONIC FM or FC series , they are Low ESR (Equivalent Series Resistance) which is a must for switch mode power supply, and 105c rating. Do not use generic electrolytic caps.
http://en.wikipedia.org/wiki/Capacitor_plague
http://i.fixya.nethttp://i.fixya.netbe827ec.jpg
Bad T-CON board or power supply problem
http://i.fixya.nethttp://i.fixya.net034e1db.jpg
24vdc power supply output testing using two 12vdc car lamps in series.
http://i.fixya.nethttp://i.fixya.net4f2929c.jpg
Bad LCD panel, vertical 1~2 pixel wide lines
http://i.fixya.nethttp://i.fixya.net28e50c1.jpg
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Free service manuals: www.elektrotanya.com
on Mar 05, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
32 lcd sony bravia, will turn on but nothing else.model kdl-32ml130. how do i repair this?
Nov 24, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Distortion and horizontl lines
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Thanks.
Nov 16, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Jun 30, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hortizontal bars at start up and blurred motion
call sony unit has bad lcd panel may ave extended warranty
Jun 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Sony BRAVIA KDL-32S2000 32 in. LCD HDTV Logo
347 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
