Question about Fuji FinePix F700 Digital Camera
The camera doesn't recognize the memory card
I have formated the memory card and also inserted new ones and the camera says "no memory card"
thanks
Edson Sieczka
    Genius:
  • 1,234 Answers
Hii
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Posted on Aug 27, 2010
    After inserting an approved memory card the following message shows up 'Memory card error' - what to do?
    Try another new memory card, if it continues to give you an error go to the main menu and look for FORMAT, some times you need to format the card so the camera can recognize the new card.
    May 24, 2014 | Canon PowerShot SX20 IS Digital Camera
    When I turn on my camera it says "Format Formatting the memory will delete all data (images/voicefiles) yes no" What does this mean?
    You are getting this because you have inserted a new memory card or a memory card which was used on a different device into your camera.
    In order for your camera to use this card, it needs to format it. In this process the camera makes changes to the card's data storing structure to suit the camera.
    If the memory card doesn't contain any data you need, answer yes.
    Apr 28, 2011 | Samsung TL100 Digital Camera
    Just purchased and installed SD memory card and the camera says memory card is unusable (Insert new memory card)
    A bunch of stuff could be happening. First did you format the new card if not see if it can be formatted to the camera. if not then you will need to download the newest updates for that camera from the Kodak web site. For example the camera is set )internally) to accept a 1gig card and you installed a 2gig card it won't recognize the card until the camera firmware is updated. The easiest way is to format the card first.
    Dec 17, 2010 | Kodak EasyShare Z710 Digital Camera
    How to insert sandisk in laptop?
    face up. gently push till it clicks. it should only fit in the slot one way. (make sure the slot is the same width as the card. Do not use the Larger slots. Typically you insert (gold) contacts down, and in first. to remove, push till you feel click, then pull. Be aware that some new micro SD cards have formats that older,( 2 years ago) laptops will not recognize. I think they are marked HD. or HC. Cards. Most of my devices Wont recognize this new format. Camera included. Cheers
    Aug 24, 2010 | SanDisk 2GB microSD Memory Card
    What memory card do I buy for my Kodak easyshare C530 camera.l The one I purchased was a SD card and it would not allow me to format.
    http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7551/7269&pq-locale=en_US&expression=sd
    The above link goes to a site that describes how SD or SDHC cards can be used in newer C cameras such as yours.
    Also, the following should be noted regarding sd cards:
    Question : Why doesn't my camera recognize the SECURE DIGITAL (SD) or MultiMedia (MMC) memory card that is in the camera? Answer : Your camera may not recognize the memory card inside for one of the following reasons:
    • The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    • The card may be corrupted. Reformat the memory card.
      CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
    • The card may not be a certified SD or MMC card. Purchase a certified SD or MMC memory card.
    See your camera's user manuals for more information. Go to KODAK Product Manuals, and select the manuals you need.
    Jul 26, 2010 | Kodak EasyShare C315 Digital Camera
    My samsung s630 says the memory is full. I cleared photos from the sd card and internal memory, but still can only take four pictures in the lowest quality and size setting.
    Memory card might gone bad but can do this following troubleshooting step. Formatting a memory ** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory. Sub menus
    [No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
    [Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear. 1d36119.png
    Be sure to run [Format] on the following types of memory card.
    - A new memory card, or an unformatted memory card
    - A memory card that has a file this camera can't recognize or one that has been taken from another camera.
    - Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message. ** There might be bad sectors on your memory card.
    Apr 12, 2010 | Samsung S630 Digital Camera
    Kodak C330 digital camera won't recognize any memory cards
    Hi sir
  • Mar 18, 2009 | Praktica DC42 Digital Camera
    Memory card is in camera(kodak c613) Camera
    Make sure the card is fully pushed in; otherwise it could be the reader.
    You could try to insert the card into an external card reader connected to a PC.
    If it is recognized by windows, click "format".
    If that works put the card back into the camera.
    If it is now recognized, go to "menu" and format again with the camera.
    If the card is not recognized, your internal card reader seems to be faulty.
    Mar 03, 2009 | Kodak EasyShare C613 Digital Camera
    Camera doesnt recognize a Secure Digitalor MultiMediamemory card?
    The cause and solution may include one of the following: The card may not be certified SD or MMC. Purchase a certified SD or MMC memory card. The card may be corrupt. Reformat the memory card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. The card is not fully inserted in the camera. Turn off the camera, insert a card into the slot, then push to seat it.
    Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
    Fuji FinePix F700 Digital Camera Logo
    Top Fuji Cameras Experts
    Steven Wander
    Steven Wander
    Parshiv Luthra
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
