Question about Kenmore 25512/ 25513 Progressive Canister Vacuum
The motor makes a weird sound and starts to heat and smell like something is burning
  • 430 Answers
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Posted on Sep 06, 2009
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
My kenmore whispertone vacuum has a weird smell
The motor may be burning out. Excessive current drain through the cord would cause it to become warm.
Jul 19, 2014 | Kenmore Vacuums
Burning smell
The response by Lynnette is in reference to the power nozzle....if you are having this issue with the main unit, then it could be the armature is starting to go bad. Have your Rainbow in front of you and give us a call. We can walk you through some steps to narrow it down.
www.rainvac.com
800-523-0510
Apr 09, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I have a steam vac spinscrub carpet cleaner works good but it just started smelling like it was burning and started to smoke
Anytime someone says they smell something burning on any type of vacuum cleaner of carpet cleaner etc. All I can think of is the belt is rubbing on plastic which would cause the sense of something burning because you possibly are smelling the belt........
Mar 12, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I love my floor mate which I bought last year. Now it is making a funny sound and has a weird burning smell. I was told to take it to a repair shop but before spending the money I want to find out if this...
It may be the belt. Sometime the motor spins but the belt is not spinning with it. This causes the belt to heat-up and burn/melt. The burned rubber maybe what you're smelling and sometime make funny noise and hard to push the vacuum.
Oct 08, 2013 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover H3030-006 240 V Motor making a loud sound and burning smell
If you have little to no suction, that sound is happening because you most likely have a clog some were in the vacuum.
smell is probably your motor over working itself do to the clog.
also double check your belts on your brushes that they are moving with the motor. smell and sound could come from the brushes being jammed which would cause the belt to freeze and heat up and could burn the belt and or your motor.
if it is still running though your not in the red yetm so triple check that the machine is cleared off all clogs and jams in the belts and brushes.
Jul 02, 2011 | Hoover H3030 FloorMate SpinScrub 500...
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Motor is sparking and smells like burning rubber. When it first happened I thought the vacuum had something jamming the beater bar. That was the smell it had, like when the belt gets burned. But when...
from sound and description most possible is motor is burnt up sparks usually mean metal on metal either bearing or bushings went on motor if u can jiggle the shaft thats bearing if u rotate the shaft by hand and feel and or hear rough grinding the brushes are damaged and the (windings)are also would need to replace motor oreck has a costumer service 800 989 3535 number give them a call not always but some times they will ship a replacement part for free
Nov 22, 2009 | Oreck Vacuums
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Burning smell
Hi. What does the burning smell of? Is it 'rubbery', or is it acrid and 'chemically'?! The most common item to 'burn' is the belt which drives the rotating brush at the front. Does your cleaner have a belt? This would give a burning rubber smell. The instructions should explain how to change the belt - have a close look and see if the belt has been slipping on the motor spindle. If it has, then it'll probably be worn at this point and should be replaced. A common cause of this happening is the brush bar getting caught in something - edge or rug, etc - and being forced to a standstill. If the smell is more 'acrid', it could be a problem with the motor. This is a repair service job.
Sep 22, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Kenmore 25512/ 25513 Progressive Canister Vacuum Logo
490 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
