Question about Garden
Kubota t1670 stalls when grass cutting - Garden
  • 3 more comments
  • bodziu Sep 04, 2009
    On riding forward when I run on thick grass while blades are engaged the engine stalls.
    I restart, cut more grass it;s fine, than a bit more grass to cut it stalls. When I ride revers not sure if it does the same, never tried
    so I'd say it happens all the time
    Kubota t1670 riding lawn tractor stalls cutting grass when I ride forward, I did not check if it happens ridding revers.
    I was cutting tall grass and thick, blades bearing got all plugged with the green fibers. I removed all blades, cleaned and lubericated all. Blades are moving freely, no problem now. I can go on cutting now 1-2 inch grass but when I run on thick taller grass the engine just cut off instantly without any hasitation. Same effect if I stand up from the seat, the engine just cut out. So it's like because I did abuse the tractor somehow, so something happened so now more load on the engine is detected like the blades are getting jammed or something. While the engine cuts out if I'm quick enough to disingage the blades it picks up again. And I go on.
  • axl3 May 11, 2010
    Does this happen only when you try to reverse or all the time?
  • Anonymous Mar 16, 2014
    Runs and cuts out as if short of fuel
    Scholar:
  • 71 Answers
Is the tractor running fine until you engage the blades? Are you cutting tall grass? There are a couple of reason why it stalls. First, while the engine is OFF, you need to see if the blades move freely, you need to lay down beside the deck and reach up (with a glove on, so you won't cut yourself) and see just what is up under there. Remove any debris, I.E. old grass clippings, and anything else.(see if there is anything wrapped around the column where the blades meet the rest of the deck) Then you will have to grab one of the blades and see if it moves freely. Wiggle it back and forth and find out if all 3 move freely. Sometimes a bearing will go bad in one of the blade mounts and cause the engine to stall. Sometimes the electric clutch goes bad and then you have a whole new set of problems. Either way let me know what is going on. Please rate my answer.
Posted on Sep 04, 2009
Testimonial: "Makes sense"
Ive replaced gas,gas lines,fuel pump on t1670 kubota.it would try to start before if you pour gas in breather.it stil does same with new parts.tried to run 1 time and died.what else could be wrong.
check and make sure the muffler is not blocked. If it is the fuel won't be allowed to enter the cylinder and fire. A plugged muffler will put back pressure on the engine.
Mar 24, 2016 | Garden
Forward and reverse appear to be getting slower
hydro drives have a habit of failing
There is a requirement to change the oil on a regular basis so it is possible that the viscosity is changing from contaminants and
oxidization
best talk with your local Kubota service dealer and see if there is a problem other than oil
Nov 13, 2015 | Garden
Tucomse moer 5.5 Won't speed up when cutting tall grass.
These push-mowers have a limited power, when you hit tall grass there is much more resistance on the blades. Even higher power riding mowers can stall on tall grass.
Aug 04, 2015 | Garden
Kubota F3680 stalls when PTO is engaged
there is not enof power so olter the tick over
Jun 28, 2015 | Kubota Garden
How do i restart my cubcadet model cc46es after it stalled because of grass
disengage pto start up move to alredy mowed area shut off and clean grass from under deck restart it turn on pto cut grass
Jul 11, 2014 | Cub Cadet Garden
Why does the engine of my Kubota ride on cut out when cutting
Sounds like you have a bad safety switch somewhere, possibly the seat switch.
Aug 10, 2012 | Kubota Garden
I have a kubota T1670 and I need a diagram to replace the new belt.. need help badly
Give a few minutes and I will find a diagram for you.
Handie Andie
Mar 26, 2011 | Garden
While mowing the grass the engine stalls and then catches back and stalls and catches back contuniually. the Murry select riding mower model number 405000x8c.
bad fuel filter, maybe cutting to fast, or grass is to high for what ever setting your at.
example. if grass is more then 10'' high, its not recommended to try and cut it to 3'' in one shot. start with the highest setting, and work it down. hope this helps.......
Sep 22, 2010 | Garden
Lawn mower stalled while cutting grass and cord
Check under the mower to see if anything is lodged in the blade, preventing it from turning. It that is clear, then the motor may have siezed up. possibly due to lack of engine oil
Sep 20, 2009 | Toro Garden
Engine stalls when blade is engaged
the best way to check is to run the engine with you on it then lift off the seat and see if the seat sensor is cutting off then put a bag with some weight in it and turn on the engine it should run ok if the sensor is working and lift the back box to see if the sensor works there.. the other cause could be a build up of grass in teh cutter area stopping the blades fron moving this can caus a stall if you get a hose and blast under the cutter guards and make shure the grass shute is clear for the grass to exit this may help to mine cuts out if there is a blockage here and the grass cant get out after it has been cut it builds up at the exit plates.. Hope this works AB
Sep 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
1,004 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
