MY JBL SUB135 IS BURNING OUT THE 2.5A 250V TYPE T FUSE
IT WILL NOT POWER ON BECAUSE THE 2.5A 250V TYPE T FUSE HAS BURNED OUT. SO I GOT NEW FUSES AND IT KEEPS BURNING OUT. WHAT CAN BE CAUSING THE FUSES TO BURN OUT?
    Novelist:
  • 133 Answers
Something is shorted on the circuit board, could be anything - switcher power transformer, rectifier diodes (or a bridge), resistors, blown, dried, leaked or shorted electrolytic capacitors in the power supply section, possibly any other shorted components in any other section.
If you're lucky, there will be visible damage to the faulty component, otherwise you will need to measure the components to find a short.
Anyway, it could be something as simple as a shorted diode or resistor in the power supply section, but i can't say anything for sure.
Hope you can get it fixed...
Regards
3rq8 (Triarcuate)
Posted on Sep 11, 2009
Hi, I have a Harman Kardon sub-woofer. When I change the fuse all I get is a humming sound. Does the type of the fuse make a difference? The fuse that I am suppose to use is a 2.5a 250v type T. Does the type T make the difference or could it be some other problem.
Posted on Jun 14, 2011
I need to find a fuse for my jbl sub 160 subwoofer.
Those are pretty common. I'd pull the old one just to make sure the new one looks like it and be SURE the new one is a "Type T" or Slo-Blo.
Google "30mm 3.15A 250v slo blo fuse" and you will find them at Mouser, DigiKey, even Amazon. Better still--if you have a local electronic parts store, go there.
Sep 28, 2015 | JBL Audio Players & Recorders
Hi, I bought a new JBL SCS 140 system with amp HK
Fuses blow when something is shorted. In this case it will be a semi-conductor of some kind. If the device uses IC for the main amplification then you are right to be worried!
The 158 amp is totally unsuitable for the JBL.
This is the specification of the JBL:
  • Recommended Amplifier Power 10 Watt
  • they are also 4 Ohm speakers.
  • 158 is: Output Impedance / Channel
    8 Ohm.
May 31, 2017 | JBL PB10 Subwoofer
I have a JBL subwoofer SUB135. When I turn it on it makes a popping noice. I am not sure what the problem is. It was recently moved when we put in hardword floors. What could be the problem, and how...
Are you sure this is new? That's a pretty common (granted annoying) trait of subwoofers. If it just makes a pop and then works fine, it's probably normal and caused by the capacitors in the power supply. If you're positive it's new, then you'll need a technician to look at the power supply. Did you change the wiring? Often subwoofers are "on" all the time and have a connection to trigger them when the reciever is turned on. That might reduce the pop rather than turning the power on and off every time...
May 31, 2011 | JBL Audio Players & Recorders
The lights do not go on at all, it does not turn on
It may be the power supply fuse. The fuse is a "2amp Type T or slo-blo 250v" if you live in north america. If your electrical current is 230v like in europe the fuse you need is "1.25amp Type T or slo blo 250v". You will need to unplug the unit from the wall outlet, unplug all cables, and set the unit on a padded surface. Remove the 10 screws holding the amplifier to the sub box and remove the amp assembly from the box. At the bottom of the circuit board is a glass fuse, gently remove that fuse and inspect it for obvious signs, like dark burn spots. If you can, check it for continuity, or just replace it. Also before going through this check the outlet that the sub is plugged into for power.
May 16, 2010 | JBL PB10 Subwoofer
Bloon Fuses!
You don't need schematics to replace the fuses.
Open the speaker unit by unscrewing the back. The fuses are located near the on/off switch assembly. Replace them and screw the the unit back together.
To avoid blown fuses, try lowering the volume.
Aug 18, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL Eon 15 Blown Fuse
These fuses are most likely 3 Amp fuses. Please note that if the replacements blow as well, that there is a problem within the amp section that will require repair.
Dan
Aug 14, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Continuing questions from Tony Fidaleo
I've sent you an email to request the copy of your PDF file to see what part in the circuit is making the fuse blow.
Jul 28, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Burn fuses
Something inside is short-circuited. All components look fine thans to burned fuse. Don't try it anymore with new fuses. You need to get a repairman to check it out.
Apr 02, 2008 | Sunpentown 11 in. SR-1330 Electric Cooktop
Reaccuring problem
The main fuse, it should 5A/250V. The one you bought is 0.5A/250V and it will burn because it can not handle the amount of current that passes through it.
The other fuse that sparks even when the TV is unplug because is the charge of a capacitor that circulates when you place the fuse.
Just curious why you had to change the fuses?
Mar 06, 2008 | Philips 60P8342 60" Rear Projection...
JBL Creature 2 Blowing Fuse
There will be a short somewhere in the power supply. If you replace the fuse it will blow again. You COULD try a larger ampage fuse, but any electrician would not recommend this!
Oct 15, 2007 | JBL CREATURE II Computer Speakers
765 people viewed this question
 Grubhead
Grubhead
