Question about Gaggia Syncrony Compact Coffee Maker/Espresso Machine
Slow grinding and coffee flow
My machine is taking too long to grind the coffee. Once it has the flow of coffee is much slower and the taste isn't what it used to be.
  • 3 Answers
Your machine has a grinder assembly, a Very expensive part to replace in its entirety. What is happening is that the conical burr set, consisting of the two metal-to-metal grinding surfaces that actually grind the beans, is now worn. Instead of grinding the beans as it once did, resulting in the proper coarseness to make perfect coffee, it is now pulverizing them instead, making the shot too fine and powdery. The result is a long, slow drip-drip-drip instead of the classic crema-rich stream you miss so much.
The cure for this of course, is to replace the conical burr set. If you're a geeky type and can handle a regular screwdriver and a finer precision phillips head, and you can get your hands on a #10 Torx drive screwdriver as well to replace the lower half of the set, the parts are available for around $42 from partsguru.com. If this is beyond your skill-set, it will cost you $95 for a diagnostic (preliminary "bend-you-over" fee), then they will charge you for the entire grider-assembly brand new, approximately $175, plus labor calculated at a Bazillion-dollars per hour. I was quoted a total around $400, with a few days turnaround time... then decided to tackle the job myself, and found it kinda fun. But then I'm a geek.
Please feel free to email me for the step-by-step procedure. It's kinda techy, but most people with the "guy-gene" in their DNA can handle it... especially at a saving of over $300!
Posted on Nov 02, 2008
  • silvjean Jan 22, 2011
    Wish I had read this several weeks ago, just sent our Gaggia grinder replaced for $300 plus shipping and now thw water doesn't come through it.
Get a service. Needs decal and the grinder cleaned
Posted on Apr 10, 2008
What do I do to make the taste of my coffee less intense/bitter?
This might sound like a joke, but I'm serious. Use less coffee. Grind size only has limited effect. When you buy different beans, you may find you need to use more or less coffee depending on the type of bean itself. In fact, I'd bet buying different brands is what is confusing you regarding how _much_ to use.
Mar 10, 2015 | Breville Coffee Makers & Espresso Machines
Why is my coffee weak?
If it is a drip maker, only gravity drives the hot water thru the coffee grinds. If the coffee is ground too fine, it immediately packs up and doesn't let water flow thru it and the water flows around the coffee instead of thru it.
Try using a coarser grind, and if not you can use a lot smaller amount of coffee and water. A smaller amount of coffee is easier to diffuse thru than a large amount.
Another thing is to slow down the water speed entering the coffee basket. I found the best way to do that is to use water just above freezing and place that extra cold water in the reservoir. The cold water takes extra time to be heated up by the coffee maker so less water is released over the coffee grinds per minute.
If your coffee maker overflows a lot, that is a good indicator that the grind is too fine and/or your coffee filters are too flimsy and are plugging up the channels in your coffee basket and the coffee can't enter the flask, so it overflows.
But the easiest way to check out your coffee maker is to use extra cold water and just run half batches (5 cup) of coffee instead of 10 cup
Feb 25, 2015 | Coffee Makers & Espresso Machines
COFFEE COMES OUT TOO FAST
Try making your coffee a finer grind. The finer the grind of the beans, the slower the water will flow through the beans. Also fresher beans will make the water flow slower due to the moisture and oil content in the beans.
Jan 07, 2014 | Starbucks Saeco Italia Digital Barista...
Set grinding and extraction on ambiente
Grinder setting will not just affect extraction time, it will also affect taste. A fine grind will be slower but have a creamier look, a coarse grind will speed up delivery. From whatever setting you are on look at the result, you are after the good creamy top of a good expresso. only adjust one step at a time, and check a few cups before any more adjustment. You do not want it so slow that you have to wait ages, So go for coarsest grind with a creamy head. Overtime you might have to readjust due to wear, Select only one hopper at a time to adjust, Do not try and adjust when blending, one side at a time until both give same result and speed for same coffee, Then you can go onto blending.
Mar 05, 2013 | Schaerer Ambiente PS Espresso Machine w/...
My coffee tastes watery. It seems as though the water flowing through the filter is going too fast. My other Keurig at work brews much slower, and the coffee is delicious.
Hi, Your coffee is ground too coarse. Make the grind finer as this will slow down the flow rate. If you go too fine it will just dribble and over extract the coffee."bitter". Dazza REPAIRER
Sep 23, 2011 | Keurig B60 Coffee Maker
My Bunn coffee filter overflows during brewing. What a mess! Is there any way to slow down the water flow?
If this is a pour-over coffeemaker, you can't do anything about the flow. It's just gravity pushing the water out of the reservoir. But you can try using a coarser grind of coffee. If the grind is too fine (if you grind whole beans for too long in a blade grinder, for instance, or if you're using espresso grind coffee), the water can't flow through quickly enough and it backs up and overflows. Make sure your coffee is ground for a drip coffeemaker.
Aug 02, 2011 | Bunn Coffee Makers & Espresso Machines
The machine it is new and coffee it comes out very quckly and has not body at all I dont know it I should to give back the espresso or it is what I can disolve myself?Any advice? please, thank you
Agreed.... you need a high quality burr grinder for a high quality espresso machine. Then put it on Fine grind and adjust the grind up or down from there until the espresso comes out with a slow smooth flow. Also be sure to tamp the grinds with a tamper so it is evenly compressed!
May 20, 2010 | Rancilio Silvia Espresso Machine
Coffee tastes waterdown
for grounds you need to tamp the ground hard,. Fill the port a filter to the top then tamp it until the little line is showing. Also what may be a problem is the grind is too fine, or too course
Feb 12, 2010 | Coffee Makers & Espresso Machines
Flow through head too fast. Coffee packed very tight and ground fine
Try grinding coffee finer.
Check the shower screen to make sure that there is no damage to it, you can use an 8mm wrench or a small flat screwdriver to remove the screen.
Is the coffee fresh ground(within a few days, 2 at the most).
Jun 10, 2009 | Rancilio Silvia Espresso Machine
Cuisinart 12-cup grinder coffemaker all gummed up
It is endemic to this unit - condensation builds up in the grind chute, which makes the grinds stick to the walls of the chute. Decalcifying with vinegar/water helps, but only in an indirect way - by keeping the inside tubing clean, decalcifying generally allows the water to flow through the machine without obstruction. Inside tubing that has calcium, lime deposits built up obstructs water, and makes it flow through the machine slower - when water flows more slowly through the machine, the machine steams off the water at a higher rate, hence more condensation builds up in the grind chute walls.
Generally, i have found all Cuisinart coffee and espresso makers to be high maintenance to a greater or lesser extent, but the Grind-n-Brews have the highest cleaning/maintenance requirement.
Mar 26, 2009 | Cuisinart Coffee Makers & Espresso...
Gaggia Syncrony Compact Coffee Maker/Espresso Machine Logo
269 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Oloyede Monsuru
Roger Jackson
Roger Jackson
Level 1 Expert
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
