Question about GE Profile JTP18 Electric Single Oven
Oven began beeping F2 for no reason. Oven was off at the time
Why is it beeping and how do I fix it?
    Guru:
  • 310 Answers
This indicates an over temperature condition occurred. This could be caused by a failed temperature sensor, failed cooling fan, or problem with the control board.
The temperature sensor can be tested with an ohm-meter (should read 1090 ohms @ 70 F). If the sensor is good, fan is running, may be welded relay contacts on the control board. We rebuild these control boards at www.fixyourboard.com.
Posted on Sep 04, 2009
F2 flashes and beeps. What does it mean?
F2 usually means that for an unknown reason, the oven temperature has exceeded a preset threshold.
Check the sensor bulb in your oven, it could be bad or your thermostat is not working properly.
Jun 19, 2011 | Magic Chef 9112 Gas Double Oven
Error code F2 keeps beeping! Will not reset. Any
thats the oven sensor , replace the sensor and your good to go
Jun 17, 2009 | GE JKP27 Electric Double Oven
GE Oven JKP26GP2 getting F2 error, even when not in use. I ohmed out the Temp sensor at room temp it is 1091ohms. The other 2 sensors check NO and NC. It's 100 bucks for a new Temp Sensor.....just don't...
F2 usually means the temp sensor is not working. here is a link to "F" codes.
http://www.repairclinic.com/0078.asp#JennAir
It has many manufacturers listed,so scroll to the GE ones.
The reason it beeps when not in use is b/c the EOC is reading the error in the part.
Good Luck!
Feb 19, 2009 | GE JKS06BFBB Electric Single Oven
F2 and F3 error messages on Tappan wall oven model 12-4980 10/03
These are the F2/F3 error codes for a Tappan oven
F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
please take the time to give this solution a fix ya rating.
clarkco
Feb 09, 2009 | Tappan Ovens
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
F2 error code
Intermittents are a real problem. My first guess: look around for a corroded or damaged electrical feed. Could be electrical noise from that. Not sure what No other possiblities other than a bad panel. I don't know what F2 is.
Dec 06, 2007 | GE JGRS14 Gas Single Oven
GE Profile JTP18 Electric Single Oven Logo
80 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
