Question about Zenith SY2549S TV
Dvd has red hite and yellow connectors...t.v has yellow and white
How do i get dvd to work? no matter how i connect, can't get t.v. to read
  • 35 Answers
Assuming the dvd IS working
you need to select av on the tv.
depending on how many in puts the tv has
just keep pressing. may be 2 or 3 times
Posted on Sep 04, 2009
How do i connect a converter box to a phillips dvd player model #dvp3340v/17
Hi there, an RF converter box can be connected to the RCA video(yellow) and audio(red /white) connectors at the rear sockets of the unit that indicate line out.
Feb 01, 2015 | Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
How do you connect the dvd player to tv ?
What kind of connection does the TV and DVD have? If it has reg cable you would put the coax cable coming off of the cable box to the in line on the DVD player and then connect another coax cable to the TV. If you have the 3 RCA connectors 1 white 1 red and 1 yellow you would connect it to an input in the back of the tv and follow the colors red to red white to white and yellow to yellow. Let me know if you need more help
Nov 10, 2010 | Insignia Televison & Video
I am trying to play back video from Sony Handycam on tv, the sound is perfect but i have no picture, im sure it must be something simple. i have handycam a/v out attached to the yellow red and white...
    First remember that the "Yellow" is for video signals the Red and White are for audio.
    first connect the camera leads directly to the TV. First yellow connector of camera attach with the "Video in" of Tv and same as Red and White of camera as Audio IN of Tv. And you will both get sound and audio.
     Now same as connect the camera connectors Yellow in Video In of the DVD and Red & White For Audio In in the DVD, Now a new lead connect to DVD out Video "yellow pin" to the TV Video IN ans same as Red & Whit in TV IN. By this procedure you will get the Video and Audio from your camera.
     Hope this will help you.
     Thanks.
Dec 01, 2009 | Sony Handycam DCR-TRV245 Digital-8 Digital...
How to connect a dvd player to lcd tv
Your DVD player's output is Composite Video (the yellow connector) plus stereo audio (the red and white connectors, for right and left audio)
The inputs on your TV are for Component Video, which splits the video signal into three cables (Y for brightness, Pb and Pr for blue and red, respectively)
Check your TV to see if it has a composite input (single yellow connector, labeled "video" or "composite")
And be sure to let me know if this helps!
Oct 24, 2009 | Televison & Video
I'm trying to connect my denon dvd player to tv
The yellow plug is composite video; the red and white are analog audio. Not knowing specifics about your TV or Denon model number, I would suggest:
-- the red and white connectors go to the audio in on the DVD, and to the audio out on the TV. There will be a left channel and a right channel. Make sure you connect the same color plug on the same channel. In other words, if you put the red plug in the right audio out on the TV, also put the red plug in the right audio in on the DVD, the white in the left audio out on the TV and in on the audio in on the DVD.
-- the yellow connector will go on the video out on the TV, video in on the DVD.
For better audio, consider using gold connectors, if you don't already have same.
Alternatively, you may wish to purchase and use an S-video connector if your equipment allows. This would replace the yellow composite video cable, and enhances your image.
Hope this helps!
May 22, 2009 | Philips Magnavox DVD/VCR Dual Player
I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
May 08, 2009 | Sanyo DVW-6100 DVD Player/VCR
How to connect to TV
The Yellow/Red/White connectors are Composite+Audio
Yellow carries a composite signal and Red and White Carry left and right audio channels.
Red Green Blue Connectors are Component
Each coloured connector carries one 'component' of the picture
So yes, your extra set of red white yellow cables would be fine to use, just make sure you connect the same colors at each end red-red green-green blue-blue
However..... the red green blue only carry the video, you will still need to carry the Audio, this is usually done either by the red and white (L & R stereo) or your DVD may also have an optical or coaxial output to carry the sound. if there is no equivalent connector on the TV then you may be stuck swapping the red/white cables, usually though there would be 2 sets of red/white connectors one set to go with the yellow, one set to go with RGB.
Apr 22, 2009 | Televison & Video
Connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Nov 18, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Trying to connect sony dvd player to hdtv
You will need some cables first. It's really not that difficult once you know what each cable does.
Since you're only connecting from the DVD player to a receiver, this should be simple.
There are 4 solutions depending on what cables you have.
Composite - Yellow, Red, and White ended connectors.
S-Video - Black 4-pin connectors.
Component - Green, Blue, Red and sometimes extra Red, White for audio.
HDMI - heavy cable with a wide/flat connector.
Composite connection - Connect the yellow end to the yellow Video Out of the DVD player and to the DVD Video In on the receiver. Connect the Red audio connector to the Red Audio out of the DVD player, the White connector to the White Audio out of the DVD player, and then connect those to the Red and White Ins for DVD Audio on the Receiver.
S-Video Connection - This is the same as the Composite video connection, but connect the black 4-pin cable into the S-Video out of the DVD player and into the In for DVD on the back of the receiver instead of using the yellow video cable. The S-Video cable is a video only cable and uses the same audio cables (the red and white ended cables) for audio.
Component Connection - On the back of the DVD player, connect the 3 video cables that are Red to Red, Blue to Blue, and Green to Green. These will be labeled Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. Connect these video cables to the inputs of the receiver the same way Y for Green, Cb/Pb for Blue, and Cr/Pr for Red. The audio connection is the same as composite and there should be a place on the DVD player that will tell you what audio is for Component. This is also the same on the back of the receiver.
HDMI Connection - This one is the easiest to connect as your audio and video are in the same cable. Plug in your HDMI cable in the back of the DVD player (there should only be one) and then to the HDMI connection for DVD on the back of the receiver.
Now...once you have your connections made, turn on your DVD player, set your receiver to DVD, and enjoy.
If your receiver does not have video inputs, you will need to run the video lines directly to your TV while the audio lines go to your receiver. This will mean you will need to set the receiver to DVD as well as change the channel of the TV to the input you have the DVD player plugged into.
I hope this helps.
May 12, 2008 | Sony DVP-NS725P DVD Player
Televison & Video Logo
46 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
