Back to:
Tags:
HP Compaq nc6230 PC Notebook
SD Card Reader won't work? (by 3 users)
posted by CO-Snowman on Dec 07, 2007
After inserting a new SD Card, nothing happens. It is not read or even notice a new device.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Sep 25, 2008
Acer laptop won't read SD card
Comment by morilori, posted on Apr 14, 2008
Hi, i have the same problem, mine appears to not work with either sd or xd cards- i am running a smartmedia 5in1 card reader factory fitted to an AcerAspire sa80 - when i insert a card nothing happens. I did as suggested to look at the device manager - it appears that it isnt even there!! HELP
Best Solution
posted on Dec 07, 2007
Helpful (85)
nickuk23
Rank:Wiz Wiz
Rating: 82%, 57 votes
have you tried other sd cards before or is this the first time?
if you have and its just this time it hasent make sure its working in your camera or mp3 player or where ever it came from :-)
if it works have a look in your device manager to make sure there are no problems with the drivers.
1 start
2 control pannel
3 system
4 then the hardware tab and click the device manager.
if there are anyproblems there is useually a little symbol next to the device just double click on it and have a look for the error code.
if all else fails try reinstaling the driver for your card reader or find an updated drivr download.
hope this helps
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on SD Card Reader won't work?:
I don't want to Accept this solution
Solution #2
posted on Mar 18, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
what is the size of this SD Card? We are beginning to conclude that the Reader in a 6230 can't read a card larger equal or larger than 2GB, we saw the same as this above except if we used smaller (256K and 1GB) cards thet worked fine.
Thank You!
Can you Help with these PC Laptops problems?
PC Laptops
I have had a pink line running vertically down my laptop...
PC Laptops
I am having bsnl broadband connection with Siemens C2110...
PC Laptops
My screen on the left has a bright pink color all the...
how do reset yhe power on passwordplease let me know at...
I have forgot my password to get into my laptop. laptop...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
