Question about Ariens 34 In. Zoom Series Riding Mower
Mower dies when the blade is engaged kawasaki 48" cut walk behind.
    Scholar:
  • 71 Answers
Well first you should check to make sure that the blades move freely. While the engine is off you can (safely, with a glove) grab one off the blades and see if you can move it freely,(the other two should move as well) By process off elimination you should be able to figure out which blade is giving you trouble. I'm guessing it could be as simple as something wrapped around the blades, to as complex as a bearing has gone bad. If this doesn't take care of your problem you can reply back, being more specific and I'll do what I can to walk you through this. Please rate my answer.
Posted on Sep 04, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
Mower runs fine turn on blades it will die
MikeMake sure that the blades will turn by hand (key out of switch- unplug the sparkplug wires!!!!) there could be a dirt mound or rock jammed in there. OR-
if you\'re in the seat and the engine dies just as soon as the blades are engaged, the engine may need a tune-up. It sounds like it starves for fuel or air under load.
May 04, 2014 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower runs fine.when u turn on blades it will die
There is a switch under the seat made to turn off the engine when the blades are "on". You have to be sitting on the seat to engage the blades. If you are, check to see if that switch is plugged into the harness. If it already is, you probably need a new switch, or less likely, but possible, the harness is damaged somewhere up the line.
My toro walk behind self propelled blade disengages how do I adjust it
No adjustment, ensure no obstruction on drive end of cable, replace cable, probably stretched over time.
Jun 17, 2012 | Toro Power Lawn Mower
Encore Premier 36 walk behind- safety switch connection problem
you can adjust the handle not the switch try and swapping the switch with the other side and see if the problem follows the switch
May 12, 2012 | Garden
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Blowing fuses
try unplugging the pto, starting the mower and then engaging the blades. If it still blows a fuse the problem lies in the mowers wiring. If not the problem is the pto. Hope this helps
Jul 13, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Ariens 34 In. Zoom Series Riding Mower Logo
239 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
