Question about Fuji Finepix Z20fd Digital Camera
Zoom error froze the function of the camera. ...how do I fix it manually? i tried turning it off and on again, that didnt' work.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 30, 2010
The zoom did not operate normally insert the battery again and turn the camera on. if the camera does not op normally do not put excessive pressure on it and contact the service center i got this error...
The solution is very simple.
you are going to remove the battery (while this screen is on) as the command screen tells.
And your camera should function properly.
I tried it and it worked.
NB; Do not try to close your camera then remove the battery.
Remove it while the camera is still on.
Jun 04, 2011 | Samsung ES30 Digital Camera
Zoom did not operate normally,insert the battery again and turn camera on again Camera doesn't operate normally
Hi had this problem with my WB100. Zoom would come out then pop back in and say zoom nit not operate normally, please put new batteries in and try again or contact bla bla. What i did when the zoom popped out is i held onto it and didnt let it retract back and turned it back on. It worked after that so i guess the zoom must of been a little forced in when it was in use last in when turned on it wasnt fully going forward. Worked for me so worth a shot
May 27, 2011 | Samsung PL120 Digital Camera
My Sony Cyber-Shot DSC-W120 Super Steady Shot zoom won't work!
Follow this procedure to troubleshoot if the zoom function does not operate.
NOTES:
  • The zoom function will not operate with some AE modes.
  • The zoom function is not available while shooting a movie on all cameras. Refer to the owner's manual for information regarding the functions available on the camera. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Change the Auto Exposure (AE) mode on the camera.
  2. Ensure the camera is not set for movie mode.
  3. If the camera has a conversion lens setting in the menu, set it of OFF.
  4. Reset the camera back to factory settings. To reset the Camera, please select Initialize under Settings and Main Settings 1.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Sep 20, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
System error zoom
i changed the memory chip and it worked just fine. something had happened to the chip causing my camera not to be able to function properly. no hammer required! :)
Mar 23, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
Powers up and then shuts off
This should work for the A520. With NEW or freshly recharged batteries, remove the camera's memory card, then turn on the camera. You'll probably see an E30 error. Next turn off the camera. Next insert the memory card, and turn on the camera.
If the above doesn't work, the following blog outlines some other repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 29, 2007 | Canon PowerShot A520 Digital Camera
Zoom error
Knocking the bottom of the lens end of the camera 3 times on a wood table, medium gentle, fixed a zoom error (where it would not focus in zoom)
The camera had been dropped whilst skiing holiday and this method fixed it. Very Happy!.
Nov 19, 2007 | Fuji FinePix Z2 Digital Camera
System error
It sounds like there is a piece of debris floating around inside the zoom motor assembly. This would explain the way it sometimes works and sometimes doesn't. It is also possible that one of the lens elements has been damaged at some point in the past and is prone to jamming now. Try gently manipulating the lens as you power on the camera, slightly twist pull and push to see if you can pop the misaligned element back into place. If this does not work you may have to send the camera in for repair. Check online for repair providers, or contact your manufacturer. David Millier Advance Camera Repair
Mar 11, 2007 | Panasonic Lumix DMC-FZ20 Digital Camera
Fuji Finepix Z20fd Digital Camera Logo
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
