Question about Jenn-Air Kitchen Ranges
What does ''F9'' on the dispay indicate? Does it have something to do with the oven lock?
  • Jenn-Air Master
  • 3,361 Answers
Yes. F-9 codes are door latch failures. Either a bad latch motor or bad micro switch usually. Need a model number to be more specific.
Posted on Sep 04, 2009
Jennair oven 8114 p472-60 or p458-60 f9 error code
The F9 error code for this model number Jenn-air range indicates a door lock issue. The control sees it as locked, unlocked, or both at the same time.
The technical manual instructs us to check the wiring to and from the door lock mechanism and if no issues are found replace the motorized door lock.
Mar 24, 2014 | Kitchen Ranges
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
May 05, 2013 | Ovens
I tried to "clean" the oven and only got a F9
The F9 error code indicates a problem with the oven door lock assembly. The door lock assembly will need to be checked and replaced if defective. If the door lock assembly is okay, then the electronic oven control board will need to be replaced.
Feb 07, 2011 | Maytag Ovens
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
Cleaning Kenmore double ovens back to back. During second cleaning got F9 code and the bottom oven is locked. Cleared the F9 will the bottom oven unlock when it cools down?
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 10, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
F9 is appearing in the clock window
HI. This will code is indicating that the oven door lock mechanism is experiencing difficulties. Check the wiring to door lock switch (the wire harness may be connected wrong, or loose). Check for stuck lock switch, as well.If the wiring is not loose, or connected improperly, this will lead to a failed door lock mech. it will require you, ro your service tech to replace it, in this case.
F-9 Oven door lock failure
Dec 07, 2009 | Whirlpool Ovens
Hi, my GE Profile Mod# JBP90GV2BB S/N ZM223214G began beeping this morning and posted an F9 code in the display. The stove hasn't been used in 2 days. What does the F9 code indicate and what ccan I do to...
F9-- Failed Lock switch detected.
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
If the wires are ok and, the switch is not stuck, replace it asap.
Jul 10, 2009 | GE Profile JTP18 Electric Single Oven
Oven door locked, F9 indicator signal
F9 has to do with the door lock/latch monitoring switch, i would try to remove the oven for mthe counter andremove the back panel, in the approximate hieght levle of hte top of the lower oven mounted to the right side( standing behind) unit youll find a small lacth / motor assy, that drivesthe self clean latch, WITH POWER TURNED OFF> i wouldlook closely at the switch mounted to the assembly make sure its not out of line , (perhaps twiste doff to the side, not making contact, or something else real obvious.. definalty related ti a faulty read of that switch .chances are it got 2 hot and distortred teh mounting and/or function of that part.. worth a try any way good luck!
Nov 27, 2008 | Kitchen Ranges
Kemore microwave model number 721.63763300
F9 is an error that indicates an inverter board or magnetron
has failed. With the F9 error cleared, start the oven and
listen for a ticking sound. The inverter will attempt to
'fire' the magnetron 5 times.(ticking sound). If can hear
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Mar 26, 2008 | Kenmore 62622 Microwave Oven
Kitchen Ranges Logo
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
