Hi------HELP!
i require set up instructions for Thompson sky digibox DS14212c DV3
i just purchased on ebay
i have a very poor aerial signal, but there is a sky dish outside,i have two connections from it inside my house which we have just recently moved to
all we want is a better quality picture,on the terrestrial channels,
we don't want to have Sky or pay for it
Many thanks
David
SOURCE: picture quality
i have a similar problem, when watching football the picture is terrible,but when im watchin ordinary tv its great
SOURCE: Can only record in black & white?
try changing your Display/ TV Connection setting under the setting menu - it may need to be set to "composite" (not RGB) if connected as displayed in the instruction manual - worked for me anyway (hope it does you).
SOURCE: Screen
Matt, The best place for the screen is going to be Ebay, look under faulty Philips mp3 players, bid on one that is faulty but has good screen.
With this unit you can practise the strip down and rebuild before you attempt your own player.
I have sent instructions on the screen replacement to your email address.
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
