How do I get the ink cartidge holder to the center of the printer (from its position on the left) so that I can change the cartridge?
  • 739 Answers
Depends on the printer - they are all different. Some do it by opening the lid, some need buttons pressing.
Posted on Sep 04, 2009
Can't get cartidge holder to stop in right place to insert new cartridge
If yours is an Epson printer, push the cartridge change button on the front panel twice. The ink carriage will retreat to the extreme right hand side. When you have loaded the new cartridge (s) push the same button twice. After a while the carriage will prime the new cartridge, the green light will come on and you may print. Other printers: For HP, open the lid with the power on. If all else fails,m I pull the plug. manually move the carriage, change the cartridge and re-power. Always try pushing the cartridge change button on the front panel first, however.
Mar 25, 2011 | Office Equipment & Supplies
Renewing ink cartidge
Turn the printer on. Lift up the cover on your printer. You will here the cartridges moving, then they will stop, in your case, i guess in the center, but if not, just look and you will surely see them (they may be either in the center or on the left or right end of the printer). Then just put your hand on the cartridge and gently pull down. You will not break anything, promise :)
Apr 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I cant change ink cartridge in my workforce500. the cartridge wont center itself so that i can open it and replace the ink
Epson has a Trouble Shooting Guide. Make sure that the 500 model number is showing on the top left. Select installing cartridges. Select Holder won't go to position. Then follow the rest of the instructions.
Here is the USER'S GUIDE, with instruction for changing the cartridges.
Hope this gets your printer working.
Good Luck
Feb 19, 2010 | Epson WorkForce 600 All-In-One InkJet...
How to install ink cartidge? hp psc 750
1. Allow your injet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
3. Press the change cartridge button. It is at the top of the printer next to the power button.
4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Feb 08, 2010 | HP PSC 750 All-In-One InkJet Printer
No printing
hi,
Check your black ink cartidge. it may be empty.change it with new balck cartridge
this problem may also be due to cartidge holder .
clean cartrideg holder with moist cotton with petrol or some other cleaning liquid as nail polish remover. clean properly the cartirdge socket and mainly the contact point of cartridge socket
Aug 20, 2009 | Lexmark X3650 Printer
Where is the ink cartidge compartment??
just raise the top lid and the cartridges will come to the center and stop
Jun 03, 2009 | Dell 926 All-In-One InkJet Printer
SX 200
unplug your printer and the pull the cartridge holder to the center while the printer is in off state..it will allow you to install the new cartridge easily...
May 14, 2009 | Epson Stylus CX3200 All-In-One InkJet...
How do I change the ink cartridge in my Lexmark x2470
How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
  1. Make sure that plain paper is loaded in the paper tray.
  2. Ensure that the power light is on.
  3. Open the cartridge door.
    The cartridge carrier may move slightly, and then return to the loading position.
  4. Push up on the cartridge lever.The cartridge holder springs open.
  5. Remove the old print cartridge and dispose of it.
  6. Remove the sticker and transparent tape from the new print cartridge.
    Warning! Do not touch the gold contact area on the print cartridge.
  7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
    Insert the color cartridge in the front carrier slot.
    Insert the black cartridge in the back carrier slot.
  8. Close the cartridge door.
  9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
  10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
Please Rate the solution.
All the Best
Sammy
Sep 26, 2008 | Lexmark Office Equipment & Supplies
I want to change ink cartridges but the cartridge holder will not go to the position
i want to chage my colour ink but the cartridge will not go into the center position hope you can help thanks a million
Jul 30, 2008 | Epson Stylus C46 InkJet Printer
Pixma mp210 problem
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
546
Jan 10, 2008 | Canon PIXMA MP160 All-In-One InkJet...
16 people viewed this question
jasbo
jasbo
