Question about Kenmore 62642 / 62644 / 62649 Microwave Oven
Vibrating noise when cooking
Microwave is making a very loud vibrating sound - only when cooking. It doesn't make the sound every time we use it, probably 70% of the time. Also, the vibrating sound starts and stops for various amounts of time while cooking - it isn't conistent.
  • 2 more comments
  • Anonymous Dec 22, 2007
    We have the same problem. Builder installed new microwave, but it is terribly noisy, and the noice seems to cycle on and off like an exhasust fan. We had Sears serviceman come out and he said it was "normal". This is the noisiest microwave we've ever had, and if this is "normal" we want our GE microwave back!!
  • melpen Dec 29, 2007
    We have a GE Spacemaker XL 1400 microwave. It is about 5-6 years old. It worked fine until I cooked bacon in it one day and there was a loud pop. Then microwave started this very loud vibrating sound and does it every time we cook in it. The noise started about 3 years ago and since microwave was only 2 yrs., we put up with it. Now, I'm getting tired of noise and appreciate other peoples quiet microwaves when we go to other homes. Appliance still heats food great - just horrible noise. I'm worried about paying a repairman to come out and tell me to just get a new one. What should I do and can noise be fixed if appliance is still heating ok?
  • ufg8torzr1 Apr 14, 2008
    GE SPACEMAKER XL1850 - Just started vibrating when turned on. I do not know what to do ? The Microwave is about 5 years old
  • vivalfuego May 21, 2008
    Mine is a Frigidaire and does something similar....only when it's in "Cook On" mode, the first 3-5 seconds makes this very loud buzzing vibrationy noise, which then subsides and it sounds and cooks normal. Is this a safety concern?
    Scholar:
  • 43 Answers
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Posted on Feb 03, 2008
Loud noise vibrating
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Please post a new help request here on FixYa and include the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc. and detailed symptoms and when they occur.
Apr 25, 2013 | Whirlpool Microwave Ovens
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Makes a loud vibrating noise when running
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 15, 2011 | Frigidaire FMV156EM Microwave Oven
Is it time to replace the microwave if it makes a loud vibrating sound followed by a pop which is followed by the sound of broken glass?
Yes it is time to replace it, the magnetron has failed and there are two more parts of concern, the high voltage capacitor and diode are also a factor. The high voltage capacitor and diode work with the magnetron to produce the high voltage that heats the food. The vibrating sound is further evidence the magnetron is culprit.
Feb 10, 2011 | Kenmore 69399 Microwave Oven
I have a 220 Advantium. I love it and it is 8 years old. When I tried to cook in it today it made a louder vibrating noise, almost like a grinding sound. Not sure that it was cooking because I stopped it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 01, 2010 | Westpoint TV-201 Microwave Oven
Purchased microwave in 2005, just stopped heating and now its making a loud noise
if the loud noise is like a vibrating noise then it sounds like the high voltage diode.
Mar 23, 2010 | Kenmore 63252 Microwave Oven
Dacor DMT2420s when started makes a loud buzzing sound
The fan could have an obstuction. I have heard of tech sheets getting into the fan and causing a vibration and vibrating sound.
May 12, 2009 | Dacor DMT2420SS Microwave Oven
Loud noise like tray vibrating. does not cook.
Call GE answer center 1-800-626-2000 ask for tech help, Have your Model # orr your data plate ready.
May 09, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Loud noise
If you mean a loud buzz that cuts on and off as the oven works, it is probably the outer metal cover vibrating as the magnetron powers up and down. Try holding/ pushing/ poking the metal cover while the oven is working, if the noise abates or goes away, this is the problem.
You may get relief by simply tightening the screws securing the cover, if not, maybe a little careful insertion of a thin strip of cardboard or similar, at the point the vibration occurs, may dampen it. Good luck.
Jan 18, 2008 | Sharp R-254 Microwave Oven
Jvm1440bd Microwave
I thought I had answered this, but maybe the reply didn't post... Vent cap? Could you be more specific about what you tried and what the noise is like - where it seems to be coming from? It looks like on some of these models, the high-voltage section emits some interference which some people are blocking with a foil or metal shield. If they do that, they should definitely insulate it to prevent shorts. Another cause of vibration on these models is a fault in the stirrer located above the cover on the ceiling inside the cooking cavity. Feel free to post back so we can help further.
Jan 08, 2007 | GE JVM1410 Microwave Oven
Kenmore 62642 / 62644 / 62649 Microwave Oven Logo
2,062 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
