The green light keeps blinking and will not go steady. I replaced the lamp, but the problem persists.
    Genius:
  • 1,689 Answers
Hi Dhhconsultin.
The blinking green light is common to Mitsubishi Televisions.
there are two buttons on the front that you pressat the same time for 5 seconds to get into the diagnostic mode. onceyou do that, one of the led's will start blinking to give you a code.for example it might blink three times followed by a pause then twoblinks. this would be code 32 . this process will repeat a coupletimes. this codes may be listed in your manual troubleshooting section.I had a problem with a 52525 model and it was code 32 which meant thatthe lamp door was open. the door itself was not really open. Just thecable to the switch that tells you the door was open was disconnected.try to figure out if the tv has any trouble codes. I cant remember thebuttons to press. follow the link where you can download the manual.look inside and it will tell you how to enter the diagnostic mode.
http://www.techlore.com/article/24711/Mitsubishi-Blinking-Green-Light-Repair-Procedure/
http://www.techlore.com/downloads/file/7714/Mitsubishi_WD52525,_62525,_52725,_62725,_52825,_62825.pdf
hope this helps.
Posted on Sep 04, 2009
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
Green light is on steady and the screen is off
Lamp cannot be tested like a regular bulb--if set shut down you should have some kind of blinking light up front---lamp possible but not likely as it should trigger the lamp light.
Either guess or call an expert to examine it.
Apr 29, 2012 | Sony Grand WEGA KFE50A10 50" SDTV LCD...
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Powers on for only a few seconds
if the power light blinks and the status light is off, check the lamp door. if the power light blinks and the status light is steady red or blinking green, you have a power supply/ballast issue. you may have to send it in for repair. try www.avsolutionsny.com.
Dec 09, 2009 | Mitsubishi XL8U Multimedia Projector
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
