Question about Yamaha 12V Air Pump
Have no spark on left engine
Yamaha LS2000 boat, 1200XT, have no spark on left engine right engine starts and runs fine. Left engine no start and no spark at plugs.
  • 101 Answers
Try disconnecting the kill switch ,or make sure its not malfuntioning ,or bad ground (s)usually this will solve no spark problems
Posted on Sep 08, 2009
My 30 year old Yamaha 75 HP outboard motor won't start despite new plugs, clean fuel and a fully charged battery. Why is this so?
Spare plug, remove spark plug cap and insert spare plug in cap. Place on metal part engine and swing engine, you are looking for a spark at plug . Do not hold plug, if electrics fine it will give you a nasty kick whispichbyou will remember. If no spark then electrics need investigating.
Oct 10, 2014 | Boating
Saturn sw2 2000 wont start
did you adjust the plugs to the right spark plug gap should be 8mm, did you put the leads back on the right spark plugs. ? firing order 1342 number one is at front. from left on dispack 4123 this is from left to right. other engine 135 246 number one top left. dispack 146 325 number one is first from left. check this is right aswell.
Mar 24, 2014 | 2000 Saturn SW2
I have a 2006 20' boat with a 4.3L Vortex engine. The started needed to replaced and after further inspection the starter looked rusty. Removed spark plugs on left side of engine and rusty water came out...
he bore on that side will be rusty so the engine has limited life
the water could be from a cracked head or head gasket problem
if the engine is at water line in the boat
, if there is no exhaust flaps at the rear of the boat , then on shutting down the engine water could have been sucked back up the exhaust on that side into the engine
( cooling manifold creates a vacuum which will suck in the water
Oct 11, 2017 | Cars & Trucks
1978 YAMAHA RD400E NO SPARK ON ONE CYLINDER BIKE RUNS ON
Remove both sparkplugs from engine. Plug them back in the sparkplug cables and let them rest on the engine.
Make sure your battery is well charged.
Check for sparks while kick-starting...
Interchange the sparkplugs in the cables:
-Same plug give sparks: replace the spark plugs.
-Same side of engine sparks: interchange the low-voltage connector at the ignition coils.
Give it a try:
Same engine side sparks: Replace the defective ignition coil.
Other side of the engine sparks: Check the circuit harness for loose connectors, and/or Clean-replace the breaker points ( left side of the engine carter ).
Aug 28, 2009 | Yamaha RD 350 Motorcycles
I replaced my spark plug wires on my 1996 chevy truck. may have crossed one,need a diagram from the spark plugs to the distributer cap.
Since you didn't state whether it is a V6 or V8, I'll give you both.
V6 -4.3Liter
Firing Order is 1-6-5-4-3-2
Distributor rotor turns Clockwise
Number 1 spark plug tower on distributor cap, faces the front of the engine.
->Drivers side, spark plug order in engine, starting from the Front going back:
1-3-5
->Passenger side, spark plug order in engine,
2-4-6
If it's Electronic, the distributor cap has a Left side, (Drivers side), and a Right side, (Passenger side)
Starting from the Front, going back on the Left side,
3-1-5
Starting from the Front going back on the Right side,
2-4-6
V8-5.0, 5.7, and 7.4Liter
Firing Order is 1-8-4-3-6-5-7-2
faces Front, towards the Drivers side.
Electronic distributor cap has two sides. Drivers, (Left), side and Passenger, (Right), side.
Starting from Front going back on Drivers side,
1-7-3-5
Starting from Front going back on Passenger side,
8-2-4-6
Spark plug order in engine, starting from Front going back, Drivers side:
1-3-5-7
Spark plug order in engine, starting from Front going back, Passenger side:
2-4-6-8
Aug 28, 2009 | 1996 Chevrolet K1500
Where does the firing order start on a 1991 3.8 buick lesabre. 165432
There are six VIN numbers of engines for the 1991 Buick Lesabre, with a 3.8 Liter engine.
1.Vin B
2.Vin 3
3.Vin C
4.Vin 1
5.Vin L
6.Vin K
All have the Firing Order of 1-6-5-4-3-2
For Vin B and 3:
Hood open, looking at the engine from the front of the car. The coil pack is behind the engine, close to the firewall. (Under the windshield)
The crankshaft pulley is down on the left side.
Spark plug numbering, for the spark plugs close to the radiator side.
From Left; (Front of engine), going Right-> 1-3-5
Spark plug numbering, for spark plugs on the backside of the engine.
From Left going Right-> 2-4-6
The distributorless coil pack sits on the backside of the engine, close to the firewall.
Numbering of where to put the spark plug wires;
There are three spark plug towers close to the engine. From Left to Right -> 3-5-7
There are three spark plug towers far from the engine. From Left to Right-> 6-4-2
For Vin C, 1, L and K:
Hood open, facing the car.
The Front of the engine faces to the Right. The crankshaft pulley is down, and to the Right.
Spark plugs close to the radiator;
Spark plugs close to firewall, (Below windshield)
From Left to Right-> 5-3-1
The distributorless coil pack sits on the right side, in front of the engine. (The Front of the engine is on the right side. The crankshaft pulley is on the Right side)
Starting at the ->Back and coming Forward. (To the Front of the car)
On the Left side of the Distributorless Coil Pack, it is -> 4-2-6
On the Right side it is -> 1-5-3
Aug 19, 2009 | 1997 Buick Skylark
Yamaha warrior won't start
If you are getting a nice bright blue spark then no, the last time I had a problem like this it was sugar in my tank. If you taste a bit off your finger and it is the slightest bit sweet, then some one has sugared your tank. If so just flush the tank with a little fresh fuel and then flush the carb, and fuel lines by spinning the engine over for a bit then try to start again.
Is yours an electronic ignition or points. If points gap could be wrong or even timing slipped. That has happened to me also.
Apr 29, 2009 | 2003 Yamaha YZ 125
Spark plug order
If you are sitting on the bike, cylinder 1 is on your left then 2,3,4....looking at the coils, the left coil- left lead goes to no1cylinder. right lead goes to cylinder4. Right coil- left lead to cylinder 2, right lead to cylinder 3.
Hope it helps you.
Apr 03, 2009 | 1986 Yamaha FZ 600
Yamaha 12V Air Pump Logo
445 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
