Question about Kenmore 24032\24036 Top Load Washer
Kenmore 60 series washer
My washing machine will not work at all. I checked the main circuit breaker in the house, reset it and still nothing. I also checked the wall outlet by plugging something else in and it worked. So it is definately a problem with the washer. What can I do?
How to calculate/Measure Agitator speed of Kenmore series 600 washer
Posted on Mar 02, 2010
  • mohajitvaish Mar 02, 2010
    How to calculate/measure agitator speed of Kenmore series 600 washer
  • 537 Answers
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Posted on Dec 07, 2007
Kenmore Washer won't power on 796.4002
Could be one of the following problems;
  • Power cord is not properly plugged in. (Make sure that the plug is plugged securely into a grounded, 3-prong, 120-VAC, 60-Hz. outlet.)
  • House fuse is blown, circuit breaker has tripped, or power outage has occured. (Reset circuit breaker or replace fuse. Do not increase fuse capacity. If the problem is a circuit overload, have it corrected by a qualified electrician.)
Source: Kenmore 79640021900 Manual
Aug 25, 2015 | Kenmore Washing Machines
Is there a fuse or circuit breaker within this washer? where?
if you try to fix it your warranty is void. so ring them and let them fix it .sounds like the main board is shot
Aug 10, 2014 | Kenmore HE2 Plus Front Load Washer
Start button doesn't work on King Size Washer
Are there any lights on at the washer? If not check the washer circuit breaker in your house main circuit breaker/service panel. If it is tripped reset it and try start button again. If it trips again you need a service call. If there are lights on try turning the washer main knob to off and unplug the washer from the wall outlet...wait 10 seconds then plug in and try start button again.
Mar 16, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
My top loading Kenmore Series 80 top loading washing will not run. When I noticed the motor would not engage agitation, I checked the circuit breaker and found that it had switched off. Turned breaker...
I would use a voltmeter and test the power to the motor. If there is power, then motor is faulty. If motor spins but not agitator then ****** could be bad. If no power to the motor, then a fuse or main circuit capacitor may be bad but testing with a manual and multi-tester meter will be needed to test for the failed componenent
Jun 09, 2012 | Kenmore series 80 Washer Motor 3363737-
I have a washer kemore 600 series, it pumps water in but will not do anything else. Is there a reset button on the motor or pump?
Hello there and welcome to fixya
If your washer doesn't seem to work at all, check these:
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? try to unplug for 15 min then reset the home breakeer than plug in the machine again and try Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. To determine if the lid switch has failed, watch the part testing video . at repair clinic.com Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. or it will fill but will stop after that
Sep 12, 2011 | Kenmore 600 3.5 cu. ft. Top Load 110-2962...
La9500xtw1 washer won't run. set dial, pulled out, and nothing happens. checked circuit breaker, and there is power in the outlet. where do we start with troubleshooting?
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 21, 2010 | Washing Machines
Kenmore washer machine cylce stopped in mid cycle
  • No power
  • Lid switch
No power
Lid switch
 check these, if still the problem persists then let me know for further help.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Fill with water - Stopped in the wash cycle - Blew Breaker
please put unit in a out by its self...recontact if still problem
Dec 15, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
1,976 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
