Question about Westinghouse LCM-19v1 Monitor
Westinghouse LCM-19w4 Problem with Monitor turning back on
I bought this monitor back in 2007 and keep it on at all times, but sleep mode on the computer turns it off after a certain amount of time. Within the past month, when I try to turn the monitor back on, it only stays on for a second and then goes black. I literally have to turn the monitor off and on again 20+ times for it to stay on. I do this every time I sit down to use the computer. Any suggestions??? I am clueless with the internals of a monitor so I don't even know what to look for. Help!!!
4 Suggested Answers
SOURCE: Westinghouse LCM-19W4
I had the same problem with my two LCM-19W4 monitors. Both failed within two months of each other. Radio Shack stocks 220uF 35V capacitors that work fine for this. You have to pay $1.49 ea though.
Posted on Aug 05, 2009
  • 1684 Answers
SOURCE: need power cable for a westinghouse lcm-19v1 sl
We carry the power cords for this model at our web site at:
www.ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Dec 29, 2009
SOURCE: Westinghouse LCM-19w4 has power, but blank screen
refer to an earlier post about similar problems. Does it power up and then shut itself off. this is possibly due to two defective capacitors. 27 cents on line $1.50 at radio shack. They will be puffy on top. I am a complete novice to soldering a capacitor onto a board. but since I was junking the monitor otherwise I gave it a try. It's still working after sitting idle a year. Handy advice on soldering online. use copper wire to **** up the old solder and try not to fry the capacitors or the board. If I did it anyone can.
Posted on Jul 04, 2010
Lcd-17v8 monitor power won't stay on. westinghouse monitor
If the monitor turns on and goes directly to sleep, or it powers on briefly and shows an image then goes black then the monitor is defective. The first is often an I/O panel issue inside of the monitor. The second is typically a lamp failure within the monitor.
A simple test would be to plug a different monitor into your computer or this monitor into another computer. If the monitor doesn't work on another computer or a different monitor works on the same computer then the monitor is the issue.
If the different monitor does not work on the same computer or this monitor does work on a different computer then something on the computer is to be suspected such as a driver issue or a faulty video card.
If you find the monitor is defective then you should dispose of it (assuming it is not under warranty) at a nearby recycling center and purchase a new monitor. I would suggest something by Acer, Samsung, Dell, HP, NEC, or Viewsonic. These brands cost a bit more, but have much better track records.
Sep 06, 2011 | Gateway FPD2275W LCD Monitor
My lcd monitor model lcm-19w4 i have to plug and unplug the monitor a few times for it to go on help
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 15, 2010 | Computers & Internet
This is a classic symptom of a failing power supply. There are parts called capacitors in the power board that will start failing and not filtering the power correctly. The regulators on the power board will not work until the power is filtered correctly and when you keep powering it on and off it fill finally start and run until you power it off, then you have to start over again. We have a step by step repair guide posted in an article on our web site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ This model is a little different from yours but the power supply parts are the same. If you have any additional questions just ask.
Buddy
Corporate Computer
www.ccl-la.com
Mar 29, 2010 | Computers & Internet
My monitor will shut itself off randomly
The power supply on this model has a know issue. We just posted the repair guide on our web site at: www.ccl-la.com It gives a step by step repair guide for the Westinghouse LCM-22W3 monitor. If you don't want to do the repair yourself do do offer a repair service for $35 plus return shipping. If youhave any questions just let us know through our web site.
I hope this helps,If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 06, 2009 | Westinghouse LCM-22w2 Television
Mar 22, 2009 | Westinghouse Computers & Internet
Westinghouse lcm 19w4 has to be used in brightest mode or
I had this same problem and going through the on-screen menus I found a reset option. I reset the monitor settings and the scrolling bars went away. I plan to leave it powered up for a while to see if they come back.
Jan 13, 2009 | Westinghouse LCM-19v1 Monitor
Happy turkey day, I have a westinghouse lcm-19w4,when I turn it on the screen flashes gray horizontal lines in the middle of the screen for a second then goes black. this happens a couple times then the...
You either have a hardware problem with your video card. ( may have pop out of socket when you plug in the monitor) or the cable is not allow communication to the monitor. As long as the amber light comes on you know you have power so focud on data cables and hardware.
Nov 27, 2008 | Computers & Internet
Nov 02, 2008 | Westinghouse LCM-19v1 Monitor
Westinghouse monitor model lcm 19w4. Screen keeps going black and you have to turn it off then back on to get screen back. Sometimes screen will work properly for hours, but sometimes keeps happening...
This looks like a power supply problem, due to internal
over heating. When it cools down, the power supply turns
back on, or an "over current/ thermal" protection circuit
trips. Shutting of the monitor off resets it, and then it trips
again.
I had an old Samsung 19" with an identical problem.
(see my other post)
Mine was caused by a leaky capacitor, but every
monitor is different. (I have considerable knowledge of
electronics, as well as a degree in engineering, so
I was able to fix it, but I would not recommend this to
a non-tech person.)
The 19w4 seems to be a fairly new wide format monitor,
probably still under warranty. I would take it back to the
store on a busy Saturday afternoon and scream blue
murder.
There is absolutely nothing you could have done to cause
this problem, nor is it normal wear and tare.
It is the result of sub-standard manufacture, and you have
every reason to take it back. Your case is stronger if
you don't try to open it.
Good luck, Martin.
please rate my answers.
Jun 14, 2008 | Computers & Internet
My Westinghouse LCM-19w4 Monitor will not turn on,..it just blinks and nothing
I just repaired my LCM 19W4. My symptoms were a little different; the light was not on or blinking like yours. I replaced two bad capacitors today (220 uF 25V High Temp) So far so good. Bad caps can be easy to identify; they are slightly bulging at the top. Soldering can be very tricky though. But just like plodder said, make sure it's the monitor that's bad and not something else by hooking up a known working monitor first.
May 18, 2008 | Computers & Internet
Westinghouse LCM-19v1 Monitor Logo
103 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
cxbxr_3
cxbxr_3
Level 1 Expert
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
