Question about Garden
5 hp tecumseh mower. plug is firing. carburator bowl is full of gas and float is working. won't start!
  • Anonymous Mar 24, 2014
    don't know what to check and how to check it. please help. thank you
    how and what do I check? thanks
  • 279 Answers
Check the flywheel key. It is the most common problem I have found when a Tecumseh either wont fire or backfires. When you have the flywheel uncovered, take a nut the same thread as the flywheel. Remove the one from your machine and use the other one for the next operation. Take the new nut, place it on the sshaft in place of the one that was there. Lift the flywheel with one hand (to get a strain on it) and with the other hand, rap the nut with either a wood mallot or a regular hammer. You may have to rap it sharply. The flywheel will come loose and you can see the problem. Go to a small engine repair shop and get a new flywheel key. Install it and go about your cutting. Good luck...Lee
Posted on Sep 04, 2009
13 hp tecumseh riding mower won't start unless gas is poured into carb. removed the bowl from carb has a wire snap holder float and needle and seat works OK and all passageways seem to be clean
hi
remove the bowl again and get the centre jet out and lok very closely use a jewlers eye piece you wll find a passage that is plugged on the side of the jet look around it you ll see some sign of a hole that is not clear through its pretty small use a welders torch cleanng tool with various size rods use very thin one dont make the hole bigger
Joe
Oct 01, 2012 | Tecumseh Garden
Toro str will not start, motor spins but will not fire
Ensure clean fuel. Always use Stabile in fuel. Follow fuel line from fuel tan to carb, ensure no leaks. Remove carb fuel bowl to check float operation. Have pliers to crimp line or use fuel shut off valve. Remove carb float bowl and clean. Float should hang down freely gas should flow. Push float up gas should cut off. Replace spark plug, ensure plug wire snaps on tight. Clean or replace air filter. Ensure oil is full, 30w oil. All mowers have low oil shutoff.
Sep 12, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
When trying to start fuel spits out of the carburator
Remove carb float bowl. Clean bowl. Get model no. of engine and get new float bowl gasket set at mower repair store. Ensure float drops down freely with float bowl removed. Push up on float to stop fuel flow. If not working properly replace float and meter needle.
May 31, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
Gas ran out of sparkplug hole
If you had raw gas in the cylinder to where it poured out of the plug hole you most likely have a carburator problem. Inside the carburator is a float and needle, the float pushes the needle into a seat when the bowl is full of gas so no more gas will flow into the bowl or the engine. If the float won't float or the needle is damaged or has dirt between it and the seat the gas will continue to flow into the carburator and on into the engine. If enough gas gets into the cylinder the starter won't be able to turn the motor over. You should also check your oil, usually when gas gets into the cylinder it runs into the crankcase and thins the oil to where it will damage the motor if run for any length of time.
May 09, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
I have a tecumseh carburator .It is the type with the float in the bowl.My problem is I can not get the carb to stop leaking gas .The float and bowl have both been replaced.It still continues to leak.I am...
Does the bowl have a drain screw that could be leaking? There may be a gasket there.
If it is leaking from the top flange, it sounds like the float is not stopping the gas.
Try taking the bowl off and holding the float up; does that stop the gas?
Do you have to push the float up beyond horizontal before the fuel stops?
If so, the plunger may have to be adjusted higher to reach the seat.
Dec 09, 2010 | Craftsman Garden
12.5 hp murray tractor while running started to mis-fire then large puff of smoke out of muffler. wont re-start gas smell in oil all remainder of gas leaked out of tank overnight!
Sounds like you have dirt in your float bowl or your float needle and seat are worn out. Pull off the float bowl and look for contamination, remove the float and see if it is full of gas (it should NOT be) and check the float needle to see if it is grooved, cracked or badly worn. Be sure you change your oil as it has gas in it!!!
Oct 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Piston blocks during start ok when spark plug removed from tecumseh motor , spark plug removed fuel runs out of piston
Remove the bowl from the carb and check to see if the float is full of gas. If not clean the needle and reinstall float and bowl.
Jul 17, 2009 | Garden
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
150 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
