Question about Toshiba Satellite Laptop
My toshiba laptop (satellite A305-S6872) when started takes me to windows error recovery screen. Gives me the option of start windows normally or launch start up rapair, neither works since it always comes back to the same screen and none of the function keys respond also. Any clue about what could be the problem and how can I solve it, thanks.
  • Toshiba Master
  • 1,606 Answers
This can be caused by several things but you have to get past this point to actually figure it out. It is a software problem ie windows, a program or a virus or even an update that is the cause. If you just installed a program or update then this is what I'd look at first. You would also want to run an antivirus boot scan.
To get into windows you will have to get into SAFEMODE. When you first push the power button push and hold F8 down. It might complain but I found on Satellites if you don't hold it down it just seems to ignore the F8 key. This will pop up a menu and at the top will be the option of booting into SAFEMODE. This boots into windows but doesn't load any drivers or programs so the offending software isn't started or run. Your windows will look different but will look right when you reboot into normal windows. Once it is running you can uninstall any recently programs if you feel that is the problem or restore the system to a previous point where it was running properly.
System restore is found under start-programs-accessories-system tools
To untinstall any programs you think might be the cause use the add remove software found under control panel.
Once you have got rid of what might be causing this then simply reboot and your should now boot into normal windows. If it goes back to the blue screen then you didn't get the cause.You can try a earlier restore point or remove other programs or updates. If those don;t fix it then you have to consider using your Toshiba system disk to restore the computer back to what it was like when your first got it. This is drastic as it wipes out everything on your hard drive. If you can get into safe mode or safe mode with network you can use a memory stick to save off your documents, music, pictures, favourites, email addresses and anything else you need to. Your cd/dvd will not work in safe mode but the usb drives do.
While this is one of those annoying problems it isn't that serious but to fix it you need to be able to see a lot of information so all I can give you here is a few things to look for. At some point you will either fix it, or have restore it or take it to a shop but without seeing it I wouldn't be able to accurately tell you when that point is.
Posted on Sep 04, 2009
  • 11,896 Answers
Run system recovery and system restore. If all else fails, boot from cd and use the recovery or windows installation disc.
Toshiba Satellite A305-S6837 is in a "DO -LOOP" with the following:
Use the Windows Install disc and load on top of previous version. Do not do a clean install, this will delete all previous settings and data.
Jan 06, 2013 | Toshiba Satellite A305-S6837 (4400 mAh)
Laptop start up problem
Have you tried performaing a recovery ?
Feb 15, 2010 | Toshiba Satellite Pro M10 Notebook
Toshiba a305 s6872, need to run recovery disk , but dvd rom will not run? what can i do???
I have a Toshiba as well, in order to boot from the dvd drive you will have to restart your machine, then when you see the Toshiba logo at startup press F12, you will see a small menu. Select your dvd rom drive from the list and press enter, if this does not work than there is still another way, keep me posted.
Feb 07, 2010 | Toshiba Satellite Laptop
How can i upgrade a305-s6872 videocard.I want to
Toshiba Satellite's are not game machines. Just put up with the error, or get a desktop.
Oct 22, 2009 | Computers & Internet
I use toshiba satellite A305-S6872 laptop would not load OS
you will most likely have to go into the recovery console to fix the problem or even re-install.
The other two solutions are to either boot up in safe mode to correct the problem by trying to revert back to a saved well working time, or take out pci cards and reboot always taking out another pci card until you find the problem.
if nothing works, re-install or fix in recovery console. <<< or >>>
BEST Solution
at re-install, choose repair windows.
Aug 24, 2009 | Computers & Internet
Laptop Assistance
Yes, the Toshiba A305-S6872 has a built in modem. It is the only port where you can plug in a phone line.
Jul 23, 2009 | Toshiba Satellite A305-S6863 Laptop
My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
May 08, 2009 | Toshiba Satellite Pro L300 Notebook
Partition the harddisk
if you have a WIN XP cd you can partition the drive with the start up after you ckick set up win
click F-8 and then install the first win screen you should see will say f to format d to delete partition ckoick the d
then are click the c to create a new partition and then f to format the new partition then load the drive
Feb 20, 2009 | Toshiba Satellite Laptop
Toshiba Satellite Laptop Logo
399 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
