Question about Canon EOS-AE-1 35mm SLR Camera
Canon AE-1 Program mirror stuck up
My 25 year old Canon AE-1 Program's mirror suddenly got stuck all the way in the up position and I cannot wind the film. The battery is brand new. How can I release the mirror myself without causing further damage to the camera? Thank you!!!
5 Suggested Answers
cammedic
  • 667 Answers
SOURCE: Hasselblad 500cm body frozen/jammed
Check the release button lock tab, it may be engaged, holding the release button in
Posted on Aug 19, 2009
  • 571 Answers
SOURCE: I have an Canon AE-1 and the film advance lever
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Posted on Dec 05, 2009
SOURCE: pentax me super mirror in up position
If the batteries are flat or missing you wont get LED's to light up and it will set itself to 125 naturally. I know as I have tried it. It could be that the shutter has got stuck on its way down and it is preventing the mirror from coming down as a result this is a mechanical issue, not battery related. The best way I found to release the mirror was to gently, really gently stroke the shutter nearest to the film down towards the groove it goes home in. Recommend a cotton budd so you don't damage the shutter leaves or get grease from your fingers on the movement. This should release the mirror. The next thing to do is try preventing the shutter getting stuck again by removing the bottom plate which will allow you access to the cogs for the shutter. it is tight in there and it is recommended by some that you remove some of the movement to see and clean them up. I did this but it is tricky and it involves winding on the camera and rocking parts out with itself. Not easy to do. The shutter cogs are brass (or look like it) and they may have old oil stuck inbetween the teeth which needs cleaning out with a tooth pick and then lubricate but not with WD40 which gets sticky with age. Use a cotton budd again with the lubricant on so you don't affect other sensitive parts around this section. Alternatively send the camera for a good service. I just had mine done, got it sorted with a warranty for 12 months to and cost me just £45. They cleaned everything up, new light seals and sorted issues common to this model of camera. The photos are instantly back to their best. Compare a good service to a series of wasted film with an inconsistent camera. Peace of mind too, it is worth it and so is the camera!
Posted on Jun 02, 2010
Tri3mast
  • 747 Answers
SOURCE: 25 year old Canon AE-1 Program SLR camera mirror
I wonder about answering posts that are a year old but here goes. The Canon AE-1 Program is a solid working classic but unfortunately Canon won't repair them anymore at least not in m y country anyway. However there are many individual repair people still bringing these cameras back from retirement to full service. Check with a local camera club or cruise e-Bay I've seen auctions selling service for these cameras in the US for as little as $79.95.
Posted on Dec 11, 2010
Advance lever is stuck. I bought new film and a new battery for my canon ae-1, loaded the new film, and took two shots until the frame counter read 1. the next day I advanced the film and when i pressed...
Like all AE-1's and related models, your camera is gumming up inside as the internal lubricant films are at least 25 years old and are largely dried-out.
The fix is to get the camera to a repair specialist for a CLA service (Clean, Lubricate, Adjust). As a one-off extra cost also get the foam light seals and foam mirror buffer replaced as they'll either be absent by now or will still be turning to a sticky goo. Modern foam is is different material and is will not decay like the old stuff.
A CLA and foam replacement definitely costs more than the residual value of the camera, but they're solidly built and have plenty of cheap high quality lenses so can still achieve results which compare well to even the best modern pro dSLR's. Get the work done and your camera will probably last until 35mm film ceases to be available. Your camera will also withstand conditions which you'd never dare risk a dSLR in.
Jun 27, 2011 | Canon EOS-AE-1 35mm SLR Camera
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
Ae1 when i advance film the shutter releases abd takes a photo
You have bad mirror release magnet.
The magnet became weak and not holding the mirror so when you wind, the mirror goes up and takes pictures or releases the shutter by itself.
Apr 27, 2010 | Canon EOS-AE-1 35mm SLR Camera
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
25 year old Canon AE-1 Program SLR camera mirror suddenly stuck up. I can catch the edge and gently pull it away, but it returns back to the stuck up position. I have already rewound most of the film back...
Sep 13, 2009 | Canon EOS-AE-1 35mm SLR Camera
Jammed canon at1 slr
Believe it or not, i just put a new battery in it and BINGO, back to life again....cheers G.
Jul 22, 2009 | Canon AV1 35mm SLR CAMERA SPARES OR REPAIR...
Canon AE-1 with Program
Have you change with a new battery?
Or check the battery with a DVM(digital volt meter).
Or get some batteries and connect in series to equal to that voltage and use two wire leads. One lead to -negative side of the battery, other lead to +positive. Now, -neg to neg of camera and +pos to pos of camera.
You now have power to the camera to test. This will save money rather than buying the camera's battery for testing. AA, C or D will work, just look on the camera's battery to see the right voltage.
Examples: with two batteries (1.5VDC + 1.5VDC = 3..0VDC). So -(negative) of one battery to + (positive) of the second battery with solder.
-(-neg, battery, pos+) solder to -(neg, 2nd battery, pos+)+
left side , use black wire on -(Neg) and solder
right side, use red wire on +(Pos) and solder.
Now you have two leads, use those to connect to camera.
Do you get data from viewfinder?
Dec 10, 2007 | Canon EOS-AE-1 35mm SLR Camera
Shutter stuck on Canon AE 1
Just now saw your problem.....I can repair this for you. No it's not "overwound" you possible have some small piece of plastic that caused your second curtain to get hung up and thus jam the entire camera. I have probably repaired 500 AE-1's with the same problem. Art www.flcamerarepair.com
Nov 22, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
602 people viewed this question
Top Canon Photography Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
