Question about Ovens
How do I remove the door from a wall oven? - Ovens
  • 220 Answers
You didn't state a brand or model but here is a sight that covers most brands   http://www.applianceaid.com/oven-hinges.html
Posted on Sep 04, 2009
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Oven door falls
jenn air wall oven
dont like the design of the hinge itself
door section has to be locked in ..
but by the design of the door capture sure looks like
the door can be removed for easier cleaning
Jun 18, 2016 | Jenn-Air Ovens
Why is the oven stuck with a "Door Locked" error?
Just guessing but did you just use the clean cycle???? During clean, the oven temp gets high enough to trip the door lock safety thermostat. This is to keep owners from trying to open the door when oven is too hot from clean cycle. It sounds like that safety didn't reset to normal when it cooled off and therefore the door is still locked. With door locked you may need to get oven out of the wall and remove top cover to get to the lock system and thermostats. Make sure power is off before doing any of this.
May 02, 2015 | GE JKP30WMWW 27" Built-in Single Electric...
E1 F5Error on Whirlpool wall oven.
The main control and door latch are not talking to each other without testing impossible to say which one on the latch assembly there are micro switches which have contacts that are open or closed depending on latch position this tells the control the position when you power up the door locks the unlocks try a latch assembly first
Jan 13, 2015 | Whirlpool RBS245PRT 24-inch Single Wall...
Removing oven doors
  • Trying to clean a late 1970s Hotpoint GE Wall Oven Model "R K746 013AD" and
  • I do not know how or if the oven door is removable.
  • See photos.
  • I am able to remove the side of the door hinge attached to the oven but am not sure about the hinge attached to the door.
  • I do not have the owners manual.
Jan 01, 2014 | Ovens
How do you remove the door from a frigidaire gallery series double wall oven(self cleaning)?
Open the door and look at the hinges the connect the oven door to the oven body, on each side you will notice a piece that can be moved back and forth without moving the door, roll each side toward the oven body this should be the locked position, now try to close the door and you will notice the hinges lift up. At this time you need to pull up and push forward on the door and both hinges will come out.
Apr 24, 2012 | Frigidaire 30 in. Electric Gallery Series...
How do I remove the hinges from a Blanco BOS402
slide the oven out from the wall. You should be able to remove the hinge from the side.
Sep 13, 2009 | Ovens
I have a wall oven, a St George single oven. The
Depending on model-
Put the door at an opening of about 100mm. You should feel an indent for thecorect position.
You will probably need 2 people, 1 each side,
Slide the door upward at an angle same as hinge, It will slide off the hinge.
If the hinge is broken, and they usually break inside the wall of the oven, it will be very difficult to slide it off the broken hinge.
Hinges are available from EDIS SPARES 1800 125 039
Sep 12, 2009 | Ovens
Remove beko oven door
You have to look under the door seal and you will find the screws you have to remove to get at the hinges screws
May 19, 2009 | Ovens
Oven door won't unlock
There is a high limit safety thermostat that acts as a one time fuse. If the outside of the oven gets too hot it will shut down power to the elements. The safety is on the behind the back wall of the oven (depending upon the model) the wall oven will have to be pulled from the wall and the back cover removed. Be sure to shut off the circuit breaker before removing the back cover. The thermo fuse should be located slightly to the right and up from the convection fan port. The door will unlock once the power is restored to the circuit. There should be a wiring diagram inside the top control area of the oven that will help your efforts.
Mar 12, 2007 | Kenmore 47813 Electric Double Oven
Ovens Logo
57 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
